Cruise Control not working
Old Jan 30, 2004 | 02:03 PM
1994maxSE's Avatar
I have a 1994 SE with 163,000 miles. The cruise control is not working. The curise control does not engage when I push the SET button on the steering wheel.
This is what happens:
1. I push the ON button on the dashboard
2. I then push the set button on the steering wheel
Result, curise control does not engage.
Another interesting thing occurs:
I first push the SET button on the steering wheel and while the SET button is pushed in, I (second) push the ON button on the dashboard. The green cruise control light on the dashboard begins to blink on and off.
Any indication what this could be and how to fix it?
Old Jan 30, 2004 | 02:11 PM
MaximaBalla's Avatar
Try taking the part of the dash off and pushing the plug and connector in all of the way? Another problem is you could have a short in your wiring. Also, check for any exposed wire w/ cuts in it or grounding onto anything.
Old Jan 30, 2004 | 02:19 PM
harrymay's Avatar
mine doesnt work like that, i have to trick it, press the set button first, then hit the dash button, then hit set. also check the vacuum hoses goin to the actuator
Old Jan 30, 2004 | 07:58 PM
james93gxe's Avatar
I'm not sure, but is there a minimum speed you have to be going before it will engage. I tried to turn mine on the other day at like 25-30 mph just to see if it worked cause I never use it and it wouldn't work.
Old Jan 31, 2004 | 10:26 AM
zzzwilliams3200's Avatar
I have the same exact problem, and I have tried to hold the button on the steering wheel too and mine will start blinking once I push the button on the dash. I checked some of the wiring but no luck finding anything wrong. I'll look some more tonight, only a matter of time I guess...
Old Jan 31, 2004 | 09:43 PM
Cliff Clavin's Avatar
Way out West
Mine wouldn't work and my brother got the entire vacuum assembly from a junkyard for $20 and voila! Cruise works. I think it just had a vacuum problem, but I never really checked it out. I still have the original one in my garage somewhere.
Oh, at first that didn't work, so I removed the battery cable overnight and when I put it back on in the morning, the cruise worked. That was almost a year ago. Still works.
Old Jan 31, 2004 | 10:32 PM
MrGone's Avatar
i wish the cruise control stuff weighted more, because I never use mine, lol.
Old Feb 1, 2004 | 05:54 AM
The minimum speed that I can set mine on is like 29 mph. So, I'm guessing the theoretical speed is 30.
Old Feb 2, 2004 | 12:08 AM
Alon26's Avatar
Does your odometer work? I had this cruise control problem b4 and also the odometer wasn't working. It turned out that my speed sensor was bad, once I changed that everything was good, odometer and cruise control..........
Old Feb 2, 2004 | 03:49 AM
nubiannupe's Avatar
OG Maxima.org Member
I actually posted this a few weeks back, but I had this same problem - EXACTLY how you described. I changed my ASCD servo and now my cruise works perfectly.
In case you're wondering, the Automatic Speed Control Device (ASCD) servo sits on the same bracket (or more specific, right beneath) as the cruise control actuator. If you've got an SE, it'll be on the passenger side of the engine bay, bolted just forward of the wheel well 'hump'. It should have a small vacuum line and a wiring harness attached to it.
Just trying to
Old Feb 2, 2004 | 09:55 AM
Way out West
hey, that whole assembly is what I replaced, so that was probably what was wrong on mine, too.
MikesChevelle
Nov 23, 2024 11:17 AM
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
MikesChevelle
Aug 6, 2015 11:36 AM
