Timing CHAIN???
Timing CHAIN???
Guys....I have a 92 Max w/ the VE engine. Is it true that those come with a timing chain instead of belt? If so, what is the replacement period on those? Thnx!
EDIT: My WP leaks so I am getting it replaced. Should I just get the chain replaced as well? How much does the chain alone cost? (parts)
The chain should last the life of the car, so long as proper maintanace is done (ie. oil/filter changes). The only thing that should wear are the chain guides/tensioners, which can also last the life of the car. I've spoken to a few mechanics and they said they never heard of the chain needing replacement.
Originally Posted by usmanasif
Sweet! Go Nissan!
MIKE
Water pump replacement isn't like on most cars that are timing belt driven. On the VE the waterpump is external and driven by the same belt as the power steering pump. I did mine in about 4 hours along with the thermostat and both radiator hoses.
And to those who like to complain about little things going wrong on their cars when they are 10+ years old lets see how well other car makes hold up after 10 years. I have 170k with no VTC noise (no rebuilds either), no exhaust studs have been replaced, and i have replaced all my window regulators and at 50 bucks a piece over a 3 year period i really cant complain. There is no such thing as a perfect car especially one with age. Well........the BMW E38 7-series is about as close to perfection as you can get.
Thanks Fashizl. Do you have any directions on how to do it? I have done some small mechanical stuff, but never anything of this magnitude.
BTW dude....your ride has one of the best paint jobs I have ever seen!
BTW dude....your ride have one of the best paint jobs I have ever seen!
from about 20 feet away
Ask MrGone
Originally Posted by Red92MaxSE
what? my red paint is just about flawless
Ask MrGone
Ask MrGone
hehehehhe almost 2 weeks..... almost
and if it didn't have the pin striping I would have already stolen it in oregon.
sooo purdy
Ahhh, I hate the light blue stripes (came on the car when I bought it -- they are painted on and clearcoated over). The ones on the spoiler are soon to be gone. Next are the ones on the sides.
Dude replacing them are a major *****! Mine did have a problem. The bolt in the timing gear backed out. It put a hole in the timing cover, the gear came loose messed up the chain, the tensioner, and the head. I ended up replacing the engine.
As for the water pump its a pretty straightforward job i believe someone has a writeup on the VE pump. I make my living working on cars all day so it was nothing to me but i remember that a lot of people have trouble getting the thing out of the car once its been unbolted. You can jack up the engine by the oil pan with a floor jack and a piece of wood (or something to distribute the weight across the oil pan. NEVER place jack directly onto an oil pan). The mounts have enough give in them to allow you to get it out. I forgot if it was from the top or the bottom but you get more room to get it out with.
Originally Posted by kennethpe
I just got my '91 Max and have not learned much about it yet - what models come with a VG or VE engine, and what's the difference - mine is a '91 SE so that's reallythe model year I am interested in
92-94 GXE = VG30E
92-94 SE = VE30DE
Originally Posted by Drivin Maxima
So I have a 90 Max GXE and your sayin that it has a timing belt???? Or am i just not understandin right and it does have a chain.
no chain for you.
I noticed when you call the auto stores they get confused on the VE engines, most stores in my area dont have parts in stock for this engine. I changed the water pump and noticed that the VE engine has a chain instead of a belt. Thank God. The pump was enough.
or a website that knows
Like mine
MIKE
Originally Posted by CanadianMaxima
whats the diff between a chain and a belt? well what i'm really trying to ask is why don't auto makers just use chains instead of belts since they don't need replacements?
The belt wears out like your tires do.
A chain wears more like your door hinge.
Originally Posted by Seyath
Besides, whats the point of making a chain that lasts forever? Then Nissan dealers cannot force you to buy more and more parts from them...
We don't want "that" happening, do we????
ANd what is the difference (other than timing chain/belt) with the VG and the VE?
But here's a few to start
VE vg
DOHC vs SOHC
10:1 VS 9:1
190 hp vs 160hp
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
