Car turns off when started unless gas pedal is pressed??
Old Feb 2, 2004 | 08:06 AM
Maxdude's Avatar
HI,
It's been two days now that when I start my car it turns right on but unless my foot is on the gas pedal, it turns right off. I start it again and starts right away but goes off again.
Then when it warms up and I have the head lights on, the power tends to decrease and when I rev it, the lights become brighter again.
Performance: No difference, runs good.
Battery is less than one year old, installed new NGK V power plugs less than a week ago. Changed cap and rotor.
My thoughts: Bad: MAF, Alternator, fuel pump????
Thanks for any suggestions.
Old Feb 2, 2004 | 08:35 AM
internetautomar's Avatar
mod or sell?
injectors probably
Old Feb 2, 2004 | 08:39 AM
Maxdude's Avatar
How do I make sure which one is bad??
Old Feb 2, 2004 | 08:49 AM
mod or sell?
You can't. Unless you have access to a flow tester.
Old Feb 2, 2004 | 08:56 AM
Maxdude's Avatar
So... What do I do? Can't afford to change'em all!!??Nissan dealer or any Mechanic shop will do??
Old Feb 2, 2004 | 09:03 AM
mod or sell?
any shop shoulkd be able to figure it out, but not too likely
Old Feb 2, 2004 | 09:46 AM
Maxdude's Avatar
What's the average cost of just checking it?
Old Feb 2, 2004 | 09:53 AM
mod or sell?
$65 is the average diagnose fee around me
Old Feb 2, 2004 | 10:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
also check IAC (round thing to the lower right of the intake manifold)
Old Feb 2, 2004 | 10:21 AM
MaximamixaM's Avatar
sounds like an idle problem. Especially if it is running smooth otherwise and has good power. When you rev to higher rpm the alternator can kick out more power and lights will be brighter. I'd run some fuel injector cleaner through it, as I think you need a good spray pattern for a good idle. Make sure spark plugs, wires, distributor are ok. Consider checking Idle air control. Lastly consider TPS.
Old Feb 2, 2004 | 10:24 AM
tmuscedere's Avatar
That would be my guess, check your IAC valve.
Old Feb 2, 2004 | 10:59 AM
Jeff92se's Avatar
I'm needing a caw
Or TPS. But check the idle air control first
Old Feb 2, 2004 | 12:33 PM
Maxdude's Avatar
Thanks guys.
Any pics of where the IAC is? How much am I looking to replace the IAC? Can I trust a used one?
thanks
Old Feb 2, 2004 | 12:43 PM
Pick up a chiltons or Haynes. Used book stores have them cheap.
Old Feb 2, 2004 | 01:07 PM
subs1000w's Avatar
Originally Posted by Maxdude
Thanks guys.
thanks
you dont need to replace it. first take it off the car and take it apart and clean it, somtimes they get all gumed up in there and dont flow well.
the other thing is you can check your MAF by unplugging it and starting your car but if oyur car starts it wont rev above 2500rpms
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
mrgooch
Aug 9, 2015 11:00 AM
