Blemco. RSB links
Old Feb 15, 2004 | 11:02 PM
ChrisCheezer's Avatar
Blemco. RSB links
- well let me just say... FIND A WELDER
- the self tapping "bolts" ripped right out of the holes, after a day.... (maybe i did somthing wrong)..
- i didnt make the holes to big,i didnt under tighten... maybe i over tightent them... (whatev
-but , a friend of mine helped me weld them in place,
i only replaced the right side.. cuz.. "if it aint broke dont fix it" is what ppl have been telling me my whole life
48 bucks.. def. worth it.. if they hold forever..
Old Feb 15, 2004 | 11:25 PM
MrGone's Avatar
if it aint broke dont fix it means no modding either.....
I dunno, Matt said he had been using the bolt method on his for 2 years or something like that, and his car is at the track alot so......
I've got some coming soon so I'll post my results aswell.
Old Feb 16, 2004 | 01:21 AM
Jack.'s Avatar
Mine went in and definately self-tapped. No problem with the bolt on method for me and its been almost 3 weeks.
Old Feb 16, 2004 | 05:46 AM
N34JZ's Avatar
Needs non-Maxima Friends
you should have welded the other side too.
Old Feb 16, 2004 | 06:28 AM
D-sta's Avatar
I used the bolts and they were welded also.
Old Feb 16, 2004 | 07:02 AM
dmontzsta's Avatar
Ford Only.
That is what I would do, just to know I have the best holding possible.
Old Feb 16, 2004 | 08:32 AM
Matt93SE's Avatar
STFU n00b!
Hmmm... what size drill bit did you use?
I haven't had a problem or heard of problems with anyone else's yet.
Old Feb 16, 2004 | 10:03 AM
Jack.'s Avatar
In my write-up I made sure it was a 7/32 drill bit. Come to think of it, drilling them in was a chore to make sure i was forcing pressure directly from beneath it.
Old Feb 16, 2004 | 10:09 AM
Pervis Anathema's Avatar
Mine have been on the car for about 2 weeks. No issues here.
Old Feb 16, 2004 | 11:09 AM
Matt93SE's Avatar
STFU n00b!
It may be a chore, but it's easier than trying to find a welder!
FYI, if you go to a muffler shop on a slow day and ask if they can weld them up for you, they'll usually do it for a couple bucks. I have yet to pay more than $5 for a quickie weld job like these. but you gotta have them on there already. you can't just drive up there with the parts in a box and say "Can you install these for me"
mount them using the screws supplied, then when you drive by on a wednesday afternoon and see that the guys are welding stick people out of exhaust scraps to stay awake... Drop in and ask if they can do 30 seconds or welding for you.
Old Feb 16, 2004 | 11:22 AM
dmontzsta's Avatar
Ford Only.
yup agreed. I would definately bolt them up then call a few shops and find out how busy they are and go down and have them weld them up as well. I can guarantee they will never come off again
Old Feb 16, 2004 | 11:25 AM
MaDMaX024's Avatar
get 'em welded definately, i have the same brackets that come in matt's kit, i will bolt them on in addition to the welding when i buy matts links and have the self tapping screws(i welded the new brackets onto the stock bracket and the frame)..these things arent goin' anywhere, ever..sadly in the process i murdered a brake line (slipped with die grinder when cleaning off the area..that was an interestingly slow drive home) so be careful if you're doing the prep work.
Old Feb 16, 2004 | 03:34 PM
i used a small bit (not sure the size) but i had to hit the tips of them in to start screwing in.
i was out today.. really wiping it around, the other stock link still holds.. and matt's welded on link looks good too..
.. still wishing i had a 5speed.......
i need a job
thatcollegestudent
18
Oct 5, 2015 02:29 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
rbaker100
Sep 25, 2015 07:52 PM
