replacing door panel speakers
want to replace the bose with aftermarket in the doors, could you guys provide any instructions on the easiest way to get them off, or any other shortcuts to minimize time? thanks
firstly, go to a junkyard and pickup some speaker mounts from a non-bose max. secondly, there are a few things you have to do.
i have a list of instructions from crutchfield, ill scan em and pdf them for if you want. but its also in the chiltons in the stickies
pm me if you need the files
ok, to remove the door panel off
i lost the instructions but ive taken my door panels off enough to know this.
step
1- remove all the screw covers (two at the front near the hinges, one in the top of the door pull handle, and one in the door open handle below the actual handle)
2- remove both the screws fron the front, the top of the pull handle, and two from the door opener cup.
3-remove the door pull handle
4- remove the cover from the door lock post
5- gently pry out door panel from the bottom up.
6- lift the panel up at the window runner
7- unplug any connections for the windows, and door courtesy light.
then all you have to do is pull out the bose unit, unplug the harness. and waa-laa,
to re-install, follow the steps backwards and make sure all the connections are back, and you may want to clean the connections up while ur in there.
hope this helps
step
hope this helps
look in the FAQs under craig brace's page. There is a section on how-tos and look under removing door panels. I think it might be in with the replacing regulators section. There are pics and even the bolts are circled on the pics.
Buy some speaker pods from James92SE. They work perfect and he can make them for either 6.5" speakers or 5.25" speakers.
They look like this
like MrGone said, they can't be beat for the price and fit just right.
They look like this
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
