Master code keyless entry (Aussie RHD)
Old Feb 18, 2004 | 07:54 PM
jacsmax's Avatar
I got a max from my grandpa and as he is getting old his memory isnt serving him well, hence he cannot tell me the code for the keyless entry. Ive searched the forum and followed one set of instructions to get the master code. This involved finding the controller box that had the master code on it. However, as the car is Australian its RHD and so im not sure of the location of this box. If anyone has any idea how i can reset the code it would be greatly appreciated.
Old Feb 18, 2004 | 08:17 PM
Harvs94max's Avatar
ok i had to do this once myself and the control box for the lhd is all the way to the right hand side of the car and up in the dash. u have to get on your back with a flash light. i think the box is like a metalic color not plastic or anything and it has a couple numbers on it i forget which number u need but if you have the write up it says. But so im asumming with your rhd it will be all the way on the left side up under the dash when u go under your dash look up and to the right it should be their i hope. remeber to bring a pad and paper with you or a helper to remember the number because im a moron and i kept forgeting the number so i was going back a forth.
Old Feb 18, 2004 | 08:41 PM
jacsmax's Avatar
there was no metalic box under either side of the dash, however, i did find a gold coloured box about 20cm x 8cm x 5cm in the boot, perhaps being an australian model this is where it is positioned. This had 2 different sets of numbers on it one in red (##### ##E##) and one in black (###-####). Does this sound familiar at all? Also, once i have the master code what is the proceedure to reset the code on the door as i have heard mixed reports?
Old Feb 18, 2004 | 08:48 PM
Harvs94max's Avatar
its been so long i forgot how but let me see if i can find the write up but i think you found the right box
Old Feb 18, 2004 | 08:55 PM
BML94GXE's Avatar
Maxima Withdrawl is real
already had this one once today
http://forums.maxima.org/showthread.php?t=286344
Old Feb 18, 2004 | 08:57 PM
Harvs94max's Avatar
This may help http://autos.groups.yahoo.com/group/...ub/message/575
Old Feb 18, 2004 | 10:14 PM
jacsmax's Avatar
after an extensive search, which required getting in the boot again to make sure i had the right numbers, i found a 3rd set of numbers (### ### #####) on a pinky/redish panel on the box (which i can now say is silver, not gold, thanks to my trusty torch!) I also visited both the above pages and followed their instructions in attempting to reset the code. The problem i had was that none of the sets of numbers i have start with a letter ('s' apparently). I tried every possible combination of numbers i have and nothing...no constant tone. I'm not sure whether being an australian model is contributing to the different looking master code and possibly also the process involving the reset. Any ideas?
Old Feb 18, 2004 | 10:34 PM
rcy's Avatar
rcy
If we assume that everything is reversed on the rhd Maxima, then you would find the box on the left side. Get on your back on the passenger side, look up under the glove box from this position. Now on the wall that is beside the glovebox (this would be to the right of the glovebox assuming you're on your back with your feet up on the passenger seat) On this outside wall of the car you should see a box (I seem to remember mine was black) with a sticker on it and the code starting with the letter 's'.
If you don't find it there, then check the same wall on the driver's side of the car.
Do a search or browse for the procedure on how to reset the code (unless you have the owner's manual which describes the procedure far better than I can).
Old Feb 19, 2004 | 12:28 PM
nismobaron's Avatar
Aussie model same as NZ model. Here's the info you need:
1) remove the corner dash trim between glovebox & left hand door (easier than trying to look at it from underneath). There's about 5 PH screws & you may have to drop glovebox. Behind this trim is the controller - it's metallic silver.
2) On the controller will be a sticker with a 7 digit code possibly with an S in front of it. Write the code down & re-assemble trim.
3) Close all the doors and:
a) Press the start/clear button on keypad
b) enter the 7 digit number. A beep will sound for 6 seconds
c) enter a 4 -7 digit personal code while the beep is sounding.
d) after your personal code has been accepted, the beep will sound at short intervals.
e) if the code entry has been unsuccessful, no beeps will be heard
Note that you cannot use sequence codes or where all the digits are on the same button. I.e. 1-2-3-4, 1-3-5-7, 1-2-1-2, 3-3-4-4, 7-5-3-1
If someone randomly pushs buttons to try and enter the car, system will shut down for 6 - 30 seconds. If you remove car battery for approx 20 days, personal code will need to be re-entered.
Print this out & put it with car ownership papers!
Old Feb 19, 2004 | 10:52 PM
jacsmax's Avatar
IT WORKS!!! A million thankyou's, ure a ledgend!!! me and max are very appreciative! Thankyou so much
Old Feb 20, 2004 | 01:00 AM
nismobaron's Avatar
You're welcome - glad it all worked out.
knight_yyz
Nov 1, 2015 01:34 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
