keyless entry on maxima used cars
Old Feb 21, 2004 | 08:41 AM
maddmax's Avatar
does any one know if the codes can be reset on 1990 maxima keyless entry panel on the door.
Old Feb 21, 2004 | 04:57 PM
internetautomar's Avatar
mod or sell?
Yes you can reset the Lock/Unlock code.
you need the master code off the gold box underdash (passenger side)
Old Feb 22, 2004 | 04:18 AM
shavedmax's Avatar
what he said
Old Mar 10, 2004 | 01:50 PM
thehecklerj's Avatar
Please provide more detailed steps please...
I have the same issue here and need to know what I do after obtaining the master code.
Please advise....
Thank you...
Old Mar 10, 2004 | 02:03 PM
dkris42's Avatar
this really should be in the FAQ sections but here is the write up.
iOkay if you are able to:
pull your passenger seat all the way back. Put your back where you feet should go and look under the glove box...as you look up look to your left you will see a gold color box with a sticker with a bunch of number lines on it. There will be one number line with a letter in front of 7 numbers. This number is your master code. Write it down or memorize it or something. Next you will need to get out of your car. Lock your doors, then you will go to the keypad and then press the “cl/st” button....it’s the first button on the left from the drivers side. After you press that you will hear a very annoying sound....during this time type in your new code...just as long as it isn’t close to the override and it isn’t all the same number...I used 4 numbers. Now do not press anything after you put your code in until the beeping stops....once the beeping has stopped enter your own code again and be able to unlock your doors open your trunk roll down your windows....if you have any problem message me or pm me on my aol.
if you are unable to get on your back you have to unscrew the glove box....but to save you time and effort just get on your back.
Nevermind...
Nevermind....
Found what I was looking for a few pages deeper.
http://forums.maxima.org/showthread.php?t=282841
Thanks...
Old Mar 10, 2004 | 02:05 PM
dkris42's Avatar
BTW
You save 60 or more doing this rather then going to the dealer.
also........ WELCOME TO THE ORG!
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
halfpol
Aug 5, 2015 08:24 PM
