Rubber roses that go in and out of the firewall
Old Feb 23, 2004 | 09:38 AM
TightBlack97's Avatar
Rubber hoses that go in and out of the firewall
Well upon some inspection that I did last week and today I found that these little some rubber hoses are linking antifreeze a little.
What are the name of the hoses that go into and out of the heater core inside the engine bay against the firewall??
Because if that is the case in that is probably one reason why my heat does not work at its greatest ability.
Any suggestions and answers!!!
Old Feb 23, 2004 | 10:06 AM
internetautomar's Avatar
mod or sell?
Heater hoses
Old Feb 23, 2004 | 06:45 PM
bansheenomore's Avatar
Heater don't work well because of low fluid. Fix the leak. Hose clamps might be loose. Core might be leaking at line also.
Old Feb 24, 2004 | 05:03 AM
Well thanks their man I already know the hose clamps are making it leak. They are on too tight and have made a little cut in the hose. I already know about the fluid and it is not low. But I guess adding some want hurt. I probably need to bleed the air out of the system too.
If the core was leaking at the line then wouldnt be all over my interior and smell bad inside the car?? This is not the case.
Old Feb 24, 2004 | 06:45 AM
Cliff Clavin's Avatar
Way out West
Sometimes when you get a core leak, it doesn't smell too bad, but your windows will fog up easy. The leak can be very tiny and there just isn't enough fluid coming out to cause it to get to the interior or smell.
I would start by replacing all of your hoses and easier stuff first and see if that fixes the problem. The heater core is a PITA. Someone did one recently up here at MrGone's house (aw89MaxSE) and I think it took all day with several guys helping out.
shilov
Feb 19, 2024 09:40 PM
fastcarny
Oct 12, 2015 07:06 AM
beerman1378
Sep 8, 2015 02:19 PM
