Power Steering ...
Old Feb 23, 2004 | 02:40 PM
91MaxGXE's Avatar
Power Steering ...
Hey everyone, I just wanted to see if you had any suggestions for me. About a week ago, I started noticing a belt squeak when I would turn my wheel sharply to one side or the other in the morning while backing out of my driveway. I checked the power steering fluid, and it seemed to be rather low. I filled it up to the line that says hot after driving the car around to let it warm up. After filling it up with power steering fluid, I drove around a little more, and when I came home, the squeaking seemed to go away. However, this morning, I began to notice it again. What else should I check and what do you think my problem is? I thought I had the problem solved when I filled up the power steering fluid...
Thanks in advance for your help.
Jeremy
BTW I checked the fluid again this morning when I started to hear the squeak again, and it was still full, so it's not leaking badly (if at all).
Old Feb 23, 2004 | 02:48 PM
Jeff92se's Avatar
I'm needing a caw
Well two obvious actions would be to check the belt's condition and tighten it to spec. How to do that? Read the stickies/buy a cheap Chiltons manual etc.....
Old Feb 25, 2004 | 06:15 PM
91MaxGXE's Avatar
OK, after monitoring the situation for a couple of days, here is what I have come up with. The car IS leaking power steering fluid, contrary to my original thoughts. After driving about 40 miles today (usually I only drive about 10-15), I noticed the squeak was much more pronounced as I came into my driveway - it must only leak while the car is running. I checked the fluid level again and it was WAY down from when I filled it on Sunday. I went and got some more, and filled it again tonight. I'll continue to watch it and see if it keeps getting low - I bought some STP stop-leak, so we'll see if that helps at all.
Thanks in advance for any more suggestions you guys might have...
Jeremy
Old Feb 25, 2004 | 06:44 PM
internetautomar's Avatar
mod or sell?
just one :
get a dye to put in the fluid so that you can find the source of the leak
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
