fine at dark and weird at day
Hi,
has any body have this problem before,
when i drive home in my car, the car seems fine at dark but get really weird at day time,
can anybody think what it is?
thanks in advince
thanks in advince
Originally Posted by masssmail
10CHAR
what iam try to saying is when the weather is cold and dark the car run fine and when the weather is warm the car thump and the idle drops a little below 1,000 rpm and goes back up and does this for a while,
could the thump mean the car is hiccuping?
ok for real... do u let ur car warm up? at all?
it could have a knock in it (one cly. is not combusting)
no check enigne light..?
for us to help u.. ya g2 be more spacific with ur problem.. is the car running rich? does it smell like gas? and get bad mpg? when does it happen at a stand still or when ur accelorating
i know for a fact that it has nothing to do with the moon
is it weird cause you cant see like you can in the day and youre driving on the side of the road in the dirt and your car feels really bumpy? try the headlights
hahahaha.....
sorry dude...but really....this post is pretty vague. you might as well just say you have a problem or type in german.
hahahaha.....
when i get out of my class i go to my car and get the car started and let it warm up, then what for a while,the window on the back is all covered up with fog so i have to clear the back and the air out of the back smell very strong but it is old so it is fine, then start to drive the car the car seems fine,
my max doesn't have the check engine light but has the emission light,
i have to put 20 to the gallon in order to last through the week before i have to refuel the tank, iam not sure if it is running rich, iam not sure if it smell like gas,
the thump happen when iam in still and in drive,
Originally Posted by harrymay
sounds lie your running rich, try an new o2 sensor, also, have you checked plugs, distributor. have you heard any knocking when you first start it. injectors may be bad also,
try ur o2 first
try ur o2 first
when the fuel in the car run out it run fine,
my by could be a fuel injectors,
what does the fuel injectors do to the car?
can i use the ecu to diagnose these problem in my max?
Originally Posted by maximagxe90
When i first start it i don't hear any thing until i put it in to drive that were i hear a sound,
I don't mean to be rude, but are from another country, not sure if its just your typing or if you are not 100% on our language yet. I wish I could help ya, but I realy dont understand what you are typeing at all.
Damon
u can see if it throws codes, bad injectors can cause that weird idling, and a clunking.
if u just bought the car, id recommend replacing the o2 sensor unless you know its just been done.
I can not see if it throws codes,
i bought the car from my grandpa and don't know if it been done yet,
id say do it anyway, you can pick up an o2 from internetautomar, he has ngk's for like 55 bux.
you can take your car to a shop or somewhere like that, i herd someone say autozone can do it.
also your maf may be bad. if temp is affecting it, the amount of air its gettin may be a problem, also temp wise, when was the last coolant flush.
these are just a few things can cause this
i don't know when the last coolant flush was,
Ok dude, to solve ur problem ur going to have to find out some things....
1- is that smell Rich fuel.. (Is the exaust really black?.. because the exuast is not suppose to be notice able.
2- pull ur plugs!- spark plugs can tell u alot of things..
3- buy a service manual..
try letting ur car fully warm -up (5-8 min.) before driving.. and see how it feels
when i first start the car the smell seem strong,
when the car is warmp up i can fell a thump when i put the car in drive and push the brake padel,
It sounds like its just going into gear.. it is a 14 year old car..VG AUTO... iv said it all (i feel ur pain)
-is that the only problem ???
**NEW PICS on my SITE**
i dont wana make a new thread about it, cuz i know the e-mails about my tails are going to poor in... whatever... peace
Hi harrmay,
But if you have over 60k on the o2 replace it.
It is a maintenance item just like an airfilter or sparkplugs.
I sell all the tune up parts BTW
Hi,
thanks in advince
thanks in advince
im kinda scared ur car might be a possesed. or a werecar like everyone else is sayin
Originally Posted by ACEGTRSKYLINE
im kinda scared ur car might be a possesed. or a werecar like everyone else is sayinstop it,
because you think this is car is possesed,
i don't think so,
this car has real problem,
i mean it,
i bit your car doesn't have problem?
you have the same trim like mine,
you have the same engine
how many miles is on the car?
your car will eventually run into problems
Hey,
stop it,
i don't think so,
i mean it,
stop it,
i don't think so,
i mean it,
I should of known when I heard a noise and I should of pulled over. For that incident I had to pay 1300 for a new disc brake, tire, rim, control arm, strut, and brake line. So at least ur problem ain't that bad.
yeah u'll find the problem... u have to try to be more spacific.. to exacly is going on, i can under stand the whole language barrier and all.. but try
- i hate when ppl say check this check this check this... oviously he doesnt know to much about cars yet so there is no point into telling him to check stuff, besides the dude said what do fuel injectors do to cars..
Hi,
2)When it thumps while you shift it, you either have a problem with the tranny or the mounts. I had the same problem with my gxe but the tech who rebuilt my tranny claimed it was the mounts. I don't know.
what iam trying to say if the fuel injector go died what problems will occure?
sorry about my grammer,
i was sleepy when i first post that message,
Originally Posted by jim90gxe
1)Do you have the Heater on while warming up the car? Usually when you smell gas only at warm-up it means the fuel lines near the injectors are cracked. When cold, these cracks expand and cause the gas to leak. When it's warmed up the cracks contract stopping the leak.
Normally i don't have the heater on while warming up the car until i clear the back windows next i get in and close my door then i turn on the heater but i wait for a while then start to go home,
like yesterday when i started the car i went to smell the pipe i smell gas from it,
somebody here told me it is the motor mounts that is causing the thump,
but not sure if it is,
Sounds like what my car was doin when I had 2 bad fuel injectors, at night when the temps were cool it would have alot more power then during the day when the outside temp got above 80F or so. It would always run rough either way. Since you dont seem to knwo that much about cars I reccomend atleast taking it to a shop and have them check it out. A few places aroud my area will do a few basic checks for little to no charge and give an estimate on repairs, although most will charge you if they run computer diagnostics.. BTW my ECU didnt throw any codes when the injectors went. Hope this helps!
i got your message
pktaske
May 6, 2016 07:49 AM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
