5th Cylinder.. Not working??
Old Feb 26, 2004 | 02:24 PM
EriCCirE's Avatar
Hey guys,
My car has been running horribly lately and now I know why. The 5th cylinder isn't working. I came to tihs becuase when I was unplugging the wires from the distrubitor all of the plug wires affected the engine except the 5th cylinder one.
I know the wires are good but can someone give me a list of what I should check? I sure hope it's not an injector.
Thanks,
Eric
Old Feb 26, 2004 | 03:27 PM
MrGone's Avatar
lay the end of the spark plug wire on the intake manifold or some other metal surface near by, you should see a spark. It is most likely an injector though. Luckily on a VG, cylinders 1-3-5 are the easy ones to change.
Old Feb 26, 2004 | 04:39 PM
internetautomar's Avatar
mod or sell?
I'd almost be willing to bet that it is an injector.
Old Feb 26, 2004 | 06:37 PM
EriCCirE's Avatar
Ouch, Yes it does spark, I managed to shock myself a couple of times while testing
Old Feb 26, 2004 | 06:53 PM
MrGone's Avatar
Well Brian sells Injectors heheh
Old Feb 27, 2004 | 01:16 PM
EriCCirE's Avatar
ok guys, I was checking the spark plugs and stuff. It turns out that the 5th cylinder was very oily, when compared to the others. The others were more or less dry and the tips kind of white. Do you think its time for e to replace the plugs?
Old Feb 28, 2004 | 07:01 PM
mod or sell?
Yes replace the plugs, but you also sound like you have blowby on the #5 cylinder which means rering time
Old Feb 29, 2004 | 07:11 AM
EriCCirE's Avatar
what should i do to fix the blow-by? replace the injector?
Old Feb 29, 2004 | 08:02 AM
mod or sell?
if it is oil, and it is blowby, you have to "rebuild" the engine to get rid of it.
Actually it's a rering, but the engine still gets torn apart.
Old Feb 29, 2004 | 05:24 PM
Maximan190's Avatar
be glad if its just an injector... mine needs an entire rebuild because of low compression on 2 cylenders
Old Feb 29, 2004 | 06:06 PM
EriCCirE's Avatar
let hope for the best. ordered the injector the other day and im going to put it in as soon as i get it.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
