Removing shift knob
Old Feb 29, 2004 | 02:39 PM
DMad8724's Avatar
Removing shift ****
How do I do this on an automatic? Come on...some of you guys that have changed to different shift *****...someone help me!
Old Feb 29, 2004 | 03:57 PM
DMad8724's Avatar
Damnit! Somebody!
Old Feb 29, 2004 | 04:07 PM
Michael's Avatar
Back in a 3rd Gen.
I did it...
I had to do some other modifying too because the shifter would hav stuck way to high for me using that universal shifter handle.
first there are a couple of screws on the front (facing the radio) that you need to take off. Then take the shifter surround off and disconect the OD button. Now push down a little (or maybe it pull up a little...cant remember) and the button should pop out. after that you just pull it up.
I cut the rod just below the plastic piece (you will see once you get in there) and the rod wouldnt sit even with the tube. I had a rubber piece (not sure what it came from) that was the exact diameter of the tube and had a hole in it almost the exact size of the shifter rod. So it worked out perfect.
If you are not comfortable fabricating stuff dont cut anything off of your shifter or you may never shift again.
Good luck,
Old Feb 29, 2004 | 04:17 PM
DMad8724's Avatar
I just need it off to get some of that trim stuff underneath of it...thanks for your help!
Old Mar 1, 2004 | 05:57 AM
89badmaxse's Avatar
Originally Posted by awsm66
I did it...
Good luck,
my 89 se is an auto and i wanted to switch but i am wondering what you did with your od switch and if it still works how did u swing that? i was thinkin of ways to do it but was to scared my od wouldnt work anymore. let me know if you get a chance
Old Mar 1, 2004 | 11:21 AM
Michael's Avatar
Back in a 3rd Gen.
I dont know are you going to read my response this time LOL? I responded to this same question you asked right here in this thread.
I am not worried about OD I never took it off really. I will probably run a switch into the console later on but right now I am not worried about it. I just un plugged it from the connector under there. its normally open which means as long as the switch isnt shorted...ie nothing plugged into the connector that can short it like a switch...then it will remain in OD. If you close the switch (short it) then it will turn OD off. So leaving it unplugged will make OD work just fine.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
atriuum
Sep 28, 2015 01:19 PM
