Power loss below 3500, not throwing knock code
Old Mar 3, 2004 | 11:51 AM
Julio's Avatar
My car doesnt have any power below 3500 rpms, and it isnt my knock sensor, cause I just put a new one in, and it isnt throwing a code, or any code for that matter. My VTC's are grounded. Sometimes for maybe a minute, my car gets all the power back, and its a huge difference. The acceleration is the same from 25%-100% throttle. I think that something is pulling my timing back and dumping fuel, but I really dont think its my knock sensor. Even before I put the new knock sensor in, i tried the resistor trick, and it didnt change a damn thing.
Old Mar 3, 2004 | 01:52 PM
MrGone's Avatar
whats your timing at?
Old Mar 3, 2004 | 04:28 PM
Julio's Avatar
Its pretty advanced right now (dont have a timing light), just as much as MadMax024, but changing it doesnt do much.
Old Mar 3, 2004 | 04:41 PM
Gjohnson's Avatar
Have you checked your ignition coils and MAF???
Old Mar 3, 2004 | 05:37 PM
Julio's Avatar
Its not any of those. All resistances check out. I have swapped MAFS before anyway.
Old Mar 4, 2004 | 02:12 PM
eric93SE's Avatar
How about the temperature sensor? the terminals usually corrode pretty badly!
Old Mar 4, 2004 | 05:46 PM
Julio's Avatar
Terminals have been cleaned, resistance checks out (at several temps), and I am not throwing any codes.
Old Mar 4, 2004 | 06:05 PM
Nismo87SE's Avatar
When you set your timing did you unplug the TPS and rev the engine 3 times to lock in timing mode? Also I'd suggest checking the TPS voltage to make sure its in spec.
Old Mar 5, 2004 | 11:56 AM
eric93SE's Avatar
My max NEVER threw a code, but there's always something wrong
Just goes to show you, the sensor/device has to TOTALLY fail to throw a code.
Old Mar 6, 2004 | 06:36 PM
internetautomar's Avatar
mod or sell?
The o2 doesn't throw codes.
Old Mar 7, 2004 | 09:12 AM
Julio's Avatar
Never even heard of that procedure. Is that in the fsm?
Old Mar 7, 2004 | 11:12 AM
eric93SE's Avatar
Yes, to set the base timming, let the engine come up to full operating temp, unplug the tps, rev the engine a few times, check/set the timming.
If the engine has trouble idling with with tps unplugged, then you probably have another problem.
Old Jul 20, 2016 | 01:31 PM
1970's Avatar
Check cooling fans
Just had same issue
One cooling fan not working the nut securing fan to motor missing
Replaced all good now
Old Jul 20, 2016 | 02:39 PM
James92SE's Avatar
2 VE's are better than one!
Originally Posted by 1970
Just had same issue
Thanks for the input. Hopefully 12 years later this will be helpful to the OP.
Old Jul 23, 2016 | 04:27 PM
Levsimus's Avatar
Old Jul 26, 2016 | 04:43 PM
Maxpwer's Avatar
No turbo, no care!
Well like he said his problem was identical, just tighten your nuts.
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
jwright36
Sep 8, 2015 11:45 AM
