i need some help...starting problems
Old Mar 5, 2004 | 08:53 AM
jarrod91se's Avatar
my car will not start by turning the key in the ignition...it only "clicks"...doesnt even turnover...but i attached a wire to the battery and clicked it against an outlet coming from the starter and it starts..i jsut replaced the ignition switch so it is not that...some help would be greatly appreciated thanks
Old Mar 5, 2004 | 08:57 AM
Jeff92se's Avatar
I'm needing a caw
Starter..........
Old Mar 5, 2004 | 09:31 AM
yelowd's Avatar
There's a starter relay switch somewhere in the car. You'll have to check the wiring diagrams. I had this happen to me on a 90 maxima. I was going to sell the car and it only did it to me in cold weather so what I did was just wire up a manual starter switch. Take a lead from a hot wire run it to a push button switch. From the other lead on the switch run it to the starter engage hook up - the one you touched to get it to turn over.
This will solve your problem until you can figure out what is causing the issue. ps- it doesn't do anything for your resell value and also make sure you get a push button switch and not a flip switch. Otherwise, your wife may end up driving around town with the starter running the whole time. She only realizes this when she goes to start the car again. Good times.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
