anyone swapped in a VG from a Quest or Villager?
Old Mar 11, 2004 | 06:40 AM
92 hatcher's Avatar
The timing belt on our 90 GXE broke. Engine and Transmission had about 180K miles on it and was running well. The timing belt broke when the car was going less than 5 miles an hour.
Instead of rebuilding, does it make sense to consider swapping in a motor from a Quest?
Does anyone know if this is a very straight forward swap to perform and what parts I would need from the Quest?
Can I just swap the long block in or is it better to swap in the engine and transmission from the Quest?
Old Mar 11, 2004 | 07:30 AM
subs1000w's Avatar
are you talking about the vg33e
Old Mar 11, 2004 | 08:15 AM
«§»Craig B«§»'s Avatar
no, I think he's talking about the non-interference version of the VG30E that was used in the Quest/Villager
I dont know if anyone has ever done this swap before. I think that VG is rated a couple hp lower but it shouldn't be much difference in power.
Old Mar 11, 2004 | 09:04 AM
mtcookson's Avatar
that would be an interesting swap since it is a non-interference engine. i may look into that thing for turbo possibilities.
Old Mar 11, 2004 | 02:10 PM
emeraldmax's Avatar
I'm confused, what do yall mean by non-interference?
Old Mar 11, 2004 | 02:18 PM
internetautomar's Avatar
mod or sell?
the VG in the max has a timing belt. and if that belt breaks the valves hit the pistons that's called an interference motor.
a non-interference motor is one where if the belt breaks the valves don't hit the pistons
Old Mar 11, 2004 | 02:27 PM
emeraldmax's Avatar
Thanx for the quick response
Old Mar 11, 2004 | 05:21 PM
Cliff Clavin's Avatar
Way out West
It seems I have an "interference" wife. When she snaps, she hits me.
I want to trade her in on a non-interference wife. Is there a direct swap available? Preferably one with more hp.
Old Mar 11, 2004 | 05:31 PM
drstillpatient's Avatar
u should change your wife every 60k miles to avoid snapping
Old Mar 11, 2004 | 05:39 PM
mtcookson's Avatar
lmfao
any know of any sites with info on this engine? i can't find crap about it.
Old Mar 11, 2004 | 06:29 PM
MaximaBalla's Avatar
Here's some side by side info. w/ the 3rd Gen. and the Quest.
http://autos.msn.com/research/compar...=t9041&v=t7201
Old Mar 11, 2004 | 07:02 PM
mtcookson's Avatar
oh wow... the bore, stroke, displacement, and compression ratio is different.
Old Mar 11, 2004 | 10:49 PM
maximagxe90's Avatar
I don't think the quest engine will fit in the max,
Old Mar 12, 2004 | 12:54 AM
92 hatcher's Avatar
If the engines from the GXE and Quest motors are both designated as VG30E, wouldn't they both have the same or similar blocks, even if the bore/strokes are slightly different???
If the Quest motor doesn't fit, could my interference VG motor still be OK since my timing belt broke when the car was travelling around 5 mph? Or is it guaranteed to have some bent valves when the timing belt broke due to the interference engine design ?
Old Mar 12, 2004 | 06:56 AM
mod or sell?
you are pretty much guaranteed bent valves if your car was moving.
Old Mar 12, 2004 | 07:10 AM
MrGone's Avatar
someone find pictures of the combustion chambers of both engines
Old Mar 12, 2004 | 07:15 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I doubt your gonna have many soccer moms running outside to tear down the motors on their Quest/Villagers to take pics for you
Old Mar 12, 2004 | 07:29 AM
lophix's Avatar
Old Mar 12, 2004 | 07:41 AM
MrGone's Avatar
Here is a half-a$$ed attempt at understanding this stuff, hehehe
Maxima VG30E
3.43xPIx3.27x6=211.311324
Non-Interference VG30E
3.50xPIx3.14x6=207.0516
but Carpoint (err I guess MSN Autos, it used to be caled carpoint) says that the Non-Interference VG30E (2982cc, 9.3:1) has more displacement and a higher compression than the Maxima VG30E(2960cc, 9.0:1).
I need more sleep hehehehe
Old Mar 12, 2004 | 07:36 PM
Maxima VG30E
Hi,
the gas pedal on the max is light,
and the gas pedal on the quest is heavy,
the max has 160hp
182Ib-ft torque
2960cc
the quest has 152hp
192Ib-ft torque
2982cc
Old Mar 13, 2004 | 01:35 AM
nismobaron's Avatar
The Quest engine will fit - would have to change the oil filter pod. Someone on the .org has done a VG33 swap into a max about 6 months back (for a net gain of 8hp...). I say if you're gonna swap to a VG33E, you may as well bore and/or stroke it out to 3.5 liters & get some decent gains
BTW: Ford demanded that Nissan supply the non-interference engine hence different bore, stroke & compression ratios. The block is the same & would probably suit some light turbocharging (7-10psi).
Old Mar 13, 2004 | 05:31 AM
Maroon'dMaxSE's Avatar
red92max...............ur crazy and funny...lol
Old Mar 13, 2004 | 11:21 AM
Bill Brasky's Avatar
Seperated at Birth?
that extra torque would be nice...
Old Mar 13, 2004 | 12:44 PM
surfermax92's Avatar
The gains from the 3.3 are nice....just not worth the money unless you do a full head job and/or get FI.
Old Mar 14, 2004 | 12:58 PM
mod or sell?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6783
it has some pics of the shortblock (heads removed)
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
