93 infinity J30 fuel injectors in VEmotor
Anyone know if the J30's fuel injectors are the same (or close to) the injectors in a 92 maxima VE motor? I think the connectors are different, but I can deal with that. All I care about is that they fit the same mounting and are around the same flow rating.
Originally Posted by Jeff92se
J30s use a VG30DE motor. Use the correct injectors for your engine. UNLESS are well versed in how injectors work, don't even try it. Even the boosted guys don't cut/solder new connectors in.
I am very well versed on fuel injector technolgy, all I need to know is the form factor, flow rate, and impedence. As for new connectors, my company designs and produce the engine harnesses for 95% of the worlds vehicles, I can handle the connector change without anyone ever noticing I did anything.
Hmm it's odd that you wouldn't know the J30's injector specifications already. Also why use the J30 units? There are plug and play injectors that don't require new connectors. ie.. why ice skake uphill?
I found a set on ebay for cheap, thats why I was thinking of useing them. As for being odd I wouldnt know the specs on the J30, I am not quite sure why I would, I would have to say there are over 10,000 different fuel injectors out there, I can't say I know the flow rate on all of them. I know they look like they are the same form factor from the picture, and I know the connectors are different(no biggy) but the spec I need that isnt available by looking at a picture, is their flow rate. I.e. 230cc, 320cc, 19pph, 21pph, etc. I am not sure if you guys here are the "into" the nitty gritty of the Maxima, not many people are. I can tell you the flow rate, pintle size, spray pattern, and form factor for every dodge magnum motor from 92 through 2004, but that cause I work with them a LOT is all.
Well for one, I believe the na Z dervived engines used injectors with a different flow rate. So even if you were able to get them going(assuming they fit/ohm ratings are compatible etc...), your car won't run correctly w/o modifing the ecu, doing some odd sizing tricks to the maf or fooling with the fuel pressures. All of which would be useless to do on a NA ve just because you saved some $ on some injectors not originally designed to fit/connect to a VE.
What I'm trying to say is that I believe the na Zs use a different rate injector. NA Z = J30 engines. I'm not cutting you down, I'm trying to explain.
Originally Posted by Damonb
I guess you are not understanding where I am getting at, I was hopeing to find out if someone knew what the flow rating of the injectors were. I am not going to buy them if they are not the same flow as the stockers. I am not looking at the TT ones, those must be larger than my VE ones. If they flow the same, I will get them and use new connectors. I am not sure why you are cuting me down on this one, I am just trying to save myself a few hundred bux here because I may have a winner, not reinvent the wheel.
flow rate on an NA Z32 is 320cc, stock VE injectors are 270cc
The stock z32 NA (VG30DE) injectors are 270cc. Trust me, I know. I am using a 300zx ECU in my car.
That is wrong. Stock VE injectors are 240cc. They are the same injector as the 4th gen.
OK, so, whats the flow rate of a J30, or are you saying the z32 is the same?
hmm....i guess Matt's FAQ for injectors is wrong
Old style, bigger injectors:
90-94 TT 300ZX, 370cc
90-93 NA 300ZX, 320cc
89-92 VG MAX, 180cc or 190cc or something
NISMO 16600-RR701, 555cc
New style, smaller injectors:
95-96 TT 300ZX, 370cc
94-96 NA 300ZX, 320cc?
93-94 VG MAX, whatever cc
92-94 VE MAX, 270cc (flow benched by RC Engineering, Jeff's injectors after cleaning)
95-99 VQ MAX, 270cc (same P/N as VE injectors)
S15 Silvia SR20DET 480cc
NISMO 16600-RR543, 555cc
NISMO 16600-RR544, 720cc
I have a set of 4th gen injectors and a set of z32tt injectors i bought, i know the tt injectors are 370cc, but as for the 4th gen, i thought they were 270cc.
Originally Posted by Matt93SE
So? What's that got to do with knowing which injectors flow what rate? Just because you have something in your car doesn't mean it's working properly.
I looked a little closer at how I have my K value tuned with the Zemulator. And when I first started out, I entered the K value that's close to a 240cc injector. I zero'd out all the fuel enrichment numbers at idle and it ran very lean. So I changed the K value until I was getting a 14.5:1 AFR at idle. The injector flow rate I ended up with is around a 280cc injector.
So, that means that the VG30DE and VE30DE injector flow rate just might be very close to being the same in my personal experience.
Damonb, I am not 100% sure that the z32 NA injectors are the same as the J30 injectors. Don't take my word on it.
emeraldmax, yes this line is wrong ... "90-93 NA 300ZX, 320cc". It's 270cc according to Ash at Z1Motorsports. So that is what he wrote his Zemulator program to accomodate for, is 270cc injectors for the NA VG30DE. And 370cc for z32 TT.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
