Interchangable 5 speed?
Old Mar 18, 2004 | 06:58 AM
Greg Qx's Avatar
Does anyone know if a 5 speed from a VE30DE twin cam, will bolt right up to a VG30E single cam. My car is a 91, and I want to replace the trans with a 5 speed from a 94. Any help is appreciated.
Old Mar 18, 2004 | 07:14 AM
subs1000w's Avatar
yes it will bolt up to the VG but you have to get the axles and spindles from a VE also for it work
Old Mar 18, 2004 | 09:09 AM
ntjoe's Avatar
Thats something I have wondered also. If someone did this swap would they need a flywheel off a VG 5 speed or off a VE, or is there a difference?
Old Mar 18, 2004 | 12:48 PM
Maxpwer's Avatar
No turbo, no care!
Subs1000w is correct, you need the spindles and axles. You will also need to adapt the different speed sensor harnesses (only a few wires). A very worth while swap IMO.
ntjoe- yes you need the VE flywheel.
Old Mar 18, 2004 | 01:30 PM
MrGone's Avatar
NOOOOOOOO NO NO NO! You do not use the VE flywheel. It is impossiable.
Oh um difference, VE has 8 bolts holding it to the crank, VG has 6.
Old Mar 18, 2004 | 02:00 PM
boosted3rdgen's Avatar
if i was swapping from a VG auto to VG 5 speed can i keep the same axles and spindles?
Old Mar 18, 2004 | 02:23 PM
MrGone's Avatar
IIRC you can reuse the passenger axle but you'll need a new drivers axle. spindles dont need to be touched.
Old Mar 19, 2004 | 06:09 AM
ntjoe's Avatar
So the VG 5spd flywheel is what you have to use for the VE tranny?
Old Mar 19, 2004 | 06:23 AM
subs1000w's Avatar
yup
i bieleve the VG and VE flywhell are phisicly the same size and specs except for the bolt patern
Old Mar 19, 2004 | 09:10 AM
icepick's Avatar
just stick a t5 trany in the b**ch
Old Mar 19, 2004 | 12:21 PM
MrGone's Avatar
t5
TKO/3550/and 56 all pwn the panzy T5
Old Mar 19, 2004 | 10:25 PM
Shadow1198's Avatar
Large Member
Nope, both auto axles work and don't need to be changed out. Everything bolts right up with no modification or "swapping" necessary. Just make sure you get ALL the manual tranny mounts (those ARE different) from the junkyard! I didn't realize they left one out when I got my stuff and ended up having to buy a new one from the dealer.
As far as the VE gearbox swapped onto the Vg, from what I understand you need the VE spindles and axles but other than that it all just bolts up. However, I'm not completely sure whether the VE/VG tranny mounts are different. I'd do this swap if I could find a decent gearbox. Open diff sucks!
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
