Bolt/screw for the door
Old Mar 22, 2004 | 06:24 AM
jett456's Avatar
I don't know what to call this, but the 'bracket' (gold in color) that holds the door closed has two screws attaching it to the door. I need to find one of these screws. My husband says it must be a special Nissan screw because he doesn't have one to match. My door won't stay closed without both of them. It's a 92 SE
Old Mar 22, 2004 | 06:33 AM
HTPerformance's Avatar
I might have one...i replaced my rear drivers door due to an accident, so...i can look thru my screw pile when i go home later...
Have an extra set of hinges too...
Brian
Old Mar 25, 2004 | 06:47 PM
Brian
I couldnt find one...have all of the screws and such for the door itself, but not the latching assembly....
Brian
Old Mar 25, 2004 | 06:56 PM
shavedmax's Avatar
if it's the door lock it has 3 screws that hold it in place, obviously you need all three to hold the door closed, but more importantly, how did you lose one? because if it just disappeared one daythen it's a good possibility that the screw broke and you may need a new lock. either way i would say go to a local junk yard, show them what you need and have them pull it for you. it shouldnt be more than 20-30 bucks for the lock.
if it's the striker( on the side of the door where it hinges) that has 2 screws, same question and suggestion as above, but if it is keeping the dor from closing you can just pull the pin out. the door should open and close freely( more than before) without nescesarally having to replace anything.
hope it helps
jwmaxse's Avatar
Do you have a junk yard in your area? That's where I get most of my bits and pieces that are missing from my cars from time to time. They probably wouldn't even charge you for it.
Old Mar 28, 2004 | 11:40 AM
jett456's Avatar
It is the striker with the two screws. I have no idea how the screw worked its way out. Nissan dealer says he will order one for me. Just a dollar or two. Thanks for all responses.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
