VG has two cams?
Old Mar 26, 2004 | 02:05 PM
Paul89SE's Avatar
VG has two cams?
I was looking at the Haynes manual and it shows 2 camshaft sprockets at the top of the engine. I'm assuming that there is a cam behind each of these sprockets. I thought SOHC meant there was only 1 cam like a pushrod engine. In the manual it looks like there is a cam over each bank of cylinders.
Old Mar 26, 2004 | 02:11 PM
Jeff92se's Avatar
I'm needing a caw
One drives the internal turbo.
SOHC = single overhead cam. aka single cam for each head. V6 = two heads, thus 1 cam for each head = 2 cam total.
VE30DE. 2 cams per head. DOHC Dual overhead cam. Thus 4 cams total.
Old Mar 26, 2004 | 02:14 PM
Jeff92se's Avatar
I'm needing a caw
He said one cam LIKE a pushrod engine. (referring to a V8 with the cam in the block). He didn't actually say the VG had pushrods
Originally Posted by slammed95
A cam for each bank of cylinders. It can't be overhead cam and have pushrods.
Old Mar 26, 2004 | 02:16 PM
Paul89SE's Avatar
I see why nobody really messes with modding cams on a VE. Too much $$$
Old Mar 26, 2004 | 03:41 PM
dmontzsta's Avatar
Ford Only.
Sort of...
VEs and VQs are VERY efficient, it is not like the old V8s where port and polish can give you 40+hp, basically just add more air/fuel now days.
Old Mar 27, 2004 | 08:35 PM
internetautomar's Avatar
mod or sell?
The VE is a quad cam
soory, too much time dealing with dumb mechanics
Old Mar 28, 2004 | 07:01 PM
james93gxe's Avatar
OHV means pushrod right?
Old Mar 28, 2004 | 07:03 PM
Paul89SE's Avatar
Nope, push rod is from the bottom. Overhead valve does not require pushrods.
Old Mar 29, 2004 | 10:13 AM
Rodrv6's Avatar
Not quite. Overhead valve means the valves are in the head (as opposed to a flathead engine like most lawnmowers). Even an old Chevy 350 is an overhead valve engine.
OHC (overhead CAM) is probably what you are thinking of. Although, there are a few overhead cam engines that do have short pushrods.
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
