clear corners fix
Old Mar 31, 2004 | 04:07 PM
maxi1's Avatar
clear corners fix
clear corners lens are coming apart from the glue
straight out the factory. anyone else have this problem
any suggustions on how to fix would be nice
Old Mar 31, 2004 | 04:55 PM
89badmaxse's Avatar
same thing happend to a pair i had take some clearsilicone put it on your figer and spread it over the gap then take a paper towel and wipe off the access give it a hour or 2 to set and you will never be able to tell or have condensation get in them.. bes tthing i can tell you to do. good luck
Old Apr 1, 2004 | 10:18 AM
markmaxima's Avatar
clear corners
buy a new set. as for the clear corner let me guess was it the right side? it happened to already , i uesd silcone, it worked for a while, then it happened again. you have a lot of companies selling them, but most of them are overprised or garbage, check interautomart, i just bought a set of eurolite clear corners from him, they went on with no problem, don't buy them from ebay. just to let me know this my third set of clear corners, 1 set customaxima, 2 set southwestautoworks, and the third set was cheaper in price
Old Apr 1, 2004 | 02:54 PM
Walka's Avatar
my understanding was that all of the 3rd gen clear corners came from the same manufacturer.. meaing that they all are cheapos... meaning they will all split evnetually. therefore, it doesnt matter where you get them.
anyone have any info which suggests otherwise?
walka
Old Apr 1, 2004 | 09:20 PM
maxi1's Avatar
corners
solved problem
got my bros heater gun took the whole lens off
heated all the glue off it was cheap glue came off easy
cleaned surface on casing and lens with alcohol, anything to
stong will dull the lenses,reaplied clear silcone let set for a day if you
can before installing. dont want to apply pressure on it before its thourally dry. if you dont do the whole lens youll be fixing it over and over and over and over get the point.till it looks like crap
Old Apr 1, 2004 | 09:21 PM
maxi1's Avatar
o yeah they do come from the same manufacture
Old Apr 1, 2004 | 09:49 PM
Jack.'s Avatar
Im confused what part of the clear corner comes off? The rubber stripping?
Old Apr 1, 2004 | 09:53 PM
maxi1's Avatar
not the rubber leave them in unless there allready out i never touched mine glue was my ptoblem
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
