Maxima Ti info 4 Shane001
Old Apr 1, 2004 | 03:02 AM
nismobaron's Avatar
is an Australia only designation Max identical to NZ SEL model (top of the range). Options are driver's airbag and fog-lights which were not optional on NZ models.
Some of the more common problems with these cars are:
Auto trans same as U11 & U12 Bluebird / Stanza which means they don't handle V6 as well - expect failure around 200,000km esp if not well maintained. On the other hand, 2nd hand trannys are cheap to get because they were fitted to U12 Bluebirds / TRX's / Corsairs...
Original window regulators are known to fail periodically - replacements are better engineered.
Early models suffered from exhaust manifold stud failure. This was fixed for 91 & later models (at least in our part of the world).
Clock display tends to fade on & off due to some bad soldering.
Anything else is what you'd expect for a 90's car - look for a well looked after car & most problems would have been taken care of by now.
Engine is VG30E - cam belt needs changing every 100,000 clicks (60,000 miles). Great car for cruising
Old Apr 2, 2004 | 02:09 AM
shane001's Avatar
Thanx for your help sounds like did a bit of research. thanks agian that's a great help
halfpol
Oct 17, 2022 12:16 PM
Turbobink
Aug 15, 2015 07:20 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
