Engine timing on 94 Se
Old Apr 5, 2004 | 04:43 PM
Bandit0867's Avatar
I had a timing belt break on me,And what i need to know is it a zero clearnace eingine. thanks.
Old Apr 5, 2004 | 04:48 PM
Mizeree_X's Avatar
Getting back to his roots
92-94 SE's have a timing chain. If you have a 92-94 GXE, then you have a belt. I believe both engines are interference engines, if that's what "zero clearance" refers to (I've never heard that term before).
Old Apr 5, 2004 | 05:49 PM
jwmaxse's Avatar
Timing belt broke on a zero clearance engine? Your screwed. I think that means that rods and stuff are bent and that kind of thing, it's going to cost more to repair the motor than jut paying for the timing belt. Sorry man. BTW-did it break on your 94 SE? It seems like it would be rare for a chain to break.
Old Apr 5, 2004 | 06:31 PM
MrGone's Avatar
on these engines you'll bend a valve before you bend a rod.
In any instance, its probably just alot cheaper to simply replace the engine than to bother rebuilding it.
Old Apr 5, 2004 | 07:56 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
you will also snap the roller rockers in half (((((insert personal experience)))))))
Old Apr 6, 2004 | 06:46 AM
CandiMan's Avatar
Say Candyman 5 times
As mentioned, if you have a belt you have a 94 GXE and not a 94 SE. All 92-94 SE's came with a timing chain. Where in West Palm are you located, I'm in the Wellington area. If you need a hand with this engine (or any other engine) let me know. I may have or know things you might need.
MIKE
Hondarydr
Dec 30, 2024 06:15 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
