Porting questions
porting doenst give you much hp, it just gets your air flow better with less friction. i dont know how much they would cost cause i did it myself with a friend, but it shouldnt be anywhere above $20 for a 20 min job. (if its the same 'porting' im talking about)
Originally Posted by gowirelessnj
lol 20 bucks ? it ran me 500 and the heads and intake were already off the car.....
Most shops don't want to fool with porting a TB. But if you already know how to port, then you already know to buy a porting kit. Summit racing is a good place to get a nice porting kit for 1/4" shanks. You can use a drill if it's a nice high speed. I used an electric rotary grinder. Air die grinders are very nice too. 1/4" shanks are the ONLY way to go. Don't ask me anything about Dremel tools.
I did port my upper and lower intake manifold myself and IMO, it's a WASTE OF TIME. For the VE that is. But people don't listen. They want to be able to tell their friends that they've done port work to their motor.
Now on the other hand VG30E motors have gotten some nice gains from port work. Be careful when porting your throttle body b/c it has a coolant jacket that you can easily pierce through if you don't know what you are doing. I've personally seen some nice dyno sheet comparison with VG30E motor's with cams and headwork. And the headwork is a very nice thing for the VGs. It's proven. But it's not yet been proven for VEs. In all my inspections, I don't see how it's possible to gain more than 5hp with a nice headwork port job on the VE30DE.
You can check out my porting pics on my webpage.
__
heh, im always wrong on pricing. this time i was way off, my apologies. porting does help a bit, but only when done right. if not done right, you can ruin your engine by having those tiny bits of aluminum get in it.
And no, porting isn't as easy as keeping metal from going in your motor.
Originally Posted by MaDMaX024
aaron is above the
dremel
tool
or maybe he just knows how to do it properly...either or
dremel
toolor maybe he just knows how to do it properly...either or
dood! if my Dremel is good enough to cut a engine block then its good enough to port a IM
really though, its cheaper to not use a dremel, the bits and crap wear out wayyyyy too quickly. Plus it boggs down too easily
I'll say it again, a dremel tool won't correctly do the job. Is it possible? Yes. Is surviving after jumping out of an airplane without a parachute possible? Yes, but I wouldn't recommend it.
bah, you need a tungsten carbide swirly bit thing ($8) and some polishing puff ***** ($2 for a pair).
the polishing wheels wear out, i used 4 on my throttle body (p+p front and back). i have 6 for my upper intake and manifold inlet..
also if you're looking to polish stuff just to make it look nice, the carbon steel brush wheel works excellent and doesnt wear out very quickly
polishing puff *****.......These would have made it alot easier, but i didnt have any polishing compund handy..... I just wet sanded with 2000 grit, it came out pretty good.
Originally Posted by Brad92SE
Aaron, yours looks a bit thinner. Was the bit you used actual sandpaper, or was it like a grinding stone?
Here is a little write up I spent many hours getting together:
http://www.littlebabywebs.com/maxima/tb/tbpage.htm
Here is the bit I am talking about:
Unclejunebug
Apr 2, 2016 05:42 AM
