Transmission causing non-working Speedometer
Old Apr 6, 2004 | 05:05 PM
zerphyte's Avatar
Hi, My speedometer/odometer are non-working. I took it to 2 mechanic's they both told me the transmission in it is a aftermarket transmission that had cable control for the speedometer(im assuming the odometer too) and my 89 Maxima SE use's electronic controlling. They basically said I'm screwed. They won't be working untill I replace the transmission(It was replaced, new.. by the previous owner) So that's not an option.
My question is:
Is they're anyway to add a aftermarket speedometer controller by cables, Like how you see the people with the huge tach's sitting on they're dash, Or is they're anyway to rig up the current speedometer to work with the cables. Thanks!
Old Apr 6, 2004 | 09:16 PM
Matt93SE's Avatar
STFU n00b!
Uhhhh, most likely those mechanics are full of crap.. you can't just throw in an aftermarket tranny and the car works...
most of the time, the problem part is the speed sensor. it's what takes the rotational signals from the tranny and converts them to electrical signals for the gauges to read.
it's about $60 from the dealer.
I highly suggest taking the car to a NISSAN mechanic and have them check it out, not a regular mechanic that says they'll work on Nissans. big difference.
Old Apr 7, 2004 | 08:21 AM
zerphyte's Avatar
Well I thought about it being the speed sensor(before I even took it to the machanics) But, the ODOMETER is non-working too, aren't they both on he same cables on the transmission?
Old Apr 7, 2004 | 09:00 AM
jim90gxe's Avatar
odo and speedo use the speed sensor for inputs.
Old Apr 7, 2004 | 02:08 PM
zerphyte's Avatar
How much do speed sensors run me/
Old Apr 7, 2004 | 06:14 PM
broncoguy's Avatar
Matt said it was about $60 from Nissan.
Old Apr 8, 2004 | 12:54 AM
89maxSE's Avatar
if you have a VG 5-speed. I have one for you for $20+shipping. Lemme know
Old Apr 8, 2004 | 08:43 AM
mtcookson's Avatar
the only way i could think of it being a cable controlled setup, on the tranny, is if it were from the 2nd gen Max but even then i don't know if those used electronics or a cable. i think those mechanics have no clue what they're talking about.
user 11122324
42
Jul 18, 2022 03:35 PM
TKHanson
Nov 24, 2018 01:39 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Pied
Sep 26, 2015 03:29 PM
