very common problem on a vg
Old Apr 7, 2004 | 10:05 AM
maximagxe90's Avatar
Hi,
can somebody tell me a very common problem on a vg?
Old Apr 7, 2004 | 10:08 AM
Jeff92se's Avatar
I'm needing a caw
Cripes O' Mighty Batman! Just read though the *cough* FAQS! and the rest of the threads here.
Old Apr 7, 2004 | 10:12 AM
subs1000w's Avatar
lack of acceleration
hahahaha
Old Apr 7, 2004 | 10:13 AM
Scope's Avatar
Im izz sexay
transmission.
Old Apr 7, 2004 | 10:15 AM
jaguax's Avatar
VG's have no problems. Just maintain it well.
Common problems throughout the car though include a disappearing/fading clock due to bad solder connections, and power window regulators breaking.
Old Apr 7, 2004 | 10:20 AM
KLoWnPR109's Avatar
FAQ you!!!!!!!!!!!!!!
Old Apr 7, 2004 | 10:22 AM
bostonbrick's Avatar
In addition to what may be in the FAQ, mine had
- one window motor failure
- antenna motor failure
Still has
- driver's side door & trunk lock mechanisms broken (I use touchpad, passenger's side door if needed)
- stock radio display broken (everything else works on the radio/cass.)
- worn shifter bushing (need to tap on the gear shifter to start engine)
Other than that, the car's been very reliable, easily one of the least problematic cars I've ever owned.
Old Apr 7, 2004 | 11:19 AM
jwmaxse's Avatar
Bad 0-60 and 1/4 mile times.
Old Apr 7, 2004 | 11:40 AM
doomtoo's Avatar
yeh, injectors went at !50k, trans at 143k, trunk lock has never worked in the time I've had it, window regulators are on last leg, clock started dimming, and turning on 1/2 the time, have to push that little thing in front of the shifter to get it out of park, gas light is broke, VC boots(all 4) tore, front suspension bad... but most of this happened before I got the car (at 143k). Stupid trans stopped a week after I bought the car.. $2900 when the car was worth $3200, then dropped $2100 in it for new tranny..
Old Apr 7, 2004 | 11:41 AM
Brad92SE's Avatar
hahahaha
exhaust manifold studs
Old Apr 7, 2004 | 11:48 AM
Hi,
i know that the vg is one of the most reliable engine for the 3gen compare to the ve that has almost alot of problems,
Old Apr 7, 2004 | 12:09 PM
«§»Craig B«§»'s Avatar
Originally Posted by maximagxe90
Hi,
The VE is also one of the most reliable engine for the 3gen (actually, there are only two engine for the 3gen)
welcome to .org, read all the FAQs
Old Apr 7, 2004 | 12:14 PM
jwmaxse's Avatar
Hi,
"ALMOST alot of problems"? I would go with the VG verses the VE if I was looking for reliability alone, but if you're in it for reliability, go get a Honda Accord. The VE's do have some issues, but I can't say that they take much away from the overall reliability and fun of the motor. The problems I've had with my VE have been frustrating, but they can be repaired if you have a little mechanical knowledge and do your research. I'd have to say that ALL the frustration goes away when you get to drive the car.
BTW, I would consider 30 less horsepower and a little less torque a HUGE problem.
Old Apr 7, 2004 | 12:18 PM
Jeff92se's Avatar
I'm needing a caw
If anyone has "almost alot" of problems, it's been me!
Hi,
Old Apr 7, 2004 | 12:47 PM
Hi,
i have one of the vg engine,
the car seems fun to drive and it is ok,
my be a little problem but i can deal with it,
i know the t-belt might need to be replace and the water pump and the tensioner but everything else seems ok,
iam going to not switch over to a honda because i like quick and fastness in a car so honda would not be good for me but a max would be good for me,
honda are a good reliable car but i don't like the inside of the car,
there little room for your leg's and the max fit me just right,
the honda accord seems a little bit slow then a max,
so no honda accord for me,
max all the way
Old Apr 7, 2004 | 01:35 PM
jwmaxse's Avatar
Yeah, I wouldn't seriously tell you to get an Accord. The max is a very reliable and sufficiently powerful car that you will probably be happy with for a long time. Just do the proper maintenance and I'm sure you will be happy with it, don't get me wrong by the above post, I DO like VG's, just not as much as VE's.
Old Apr 7, 2004 | 01:38 PM
Jeff92se's Avatar
I'm needing a caw
Depends on WHICH Accord. The ones with the V6 are faster than a VG max
Old Apr 7, 2004 | 07:33 PM
Shadow1198's Avatar
Large Member
Injectors are a problem on Vg's. They are ~170cc so they'd be running at a high duty cycle most of the time. From what I remember, injectors running at 80%+ duty cycle all the time wear out quick. Well, put on some mods on a Vg maxima and you are pretty close to that!
Old Apr 7, 2004 | 09:41 PM
mtcookson's Avatar
trunk lock as in the lever/button or the key? if its the lever/button then open the trunk and flip that switch on the latching mechanism
i beg to differ.... ok so i do have some mods on my car
Old Apr 8, 2004 | 12:02 AM
nismax1994's Avatar
front wheels spin too much
Old Apr 8, 2004 | 05:42 AM
89badmaxse's Avatar
finally a pic of a max streched i love that!
Old Apr 8, 2004 | 05:52 AM
that's a real pic of a maxima limo
it's from South Africa
Old Apr 8, 2004 | 05:58 AM
Scope's Avatar
Im izz sexay
that is frakin hot I want one imported sob..sob...
Old Apr 8, 2004 | 06:50 PM
super32's Avatar
Donating member? what the?!
exactly
VG30E stands for "Very Good 3.0 Engine"
on window regulators, exhaust studs, timing belt, slow-shifting tranny(AT). I've noticed some lousy electrical work, but nothing to the point where your car won't keep running fine.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Maximeltman
Sep 28, 2015 07:19 PM
Noela
Sep 26, 2015 08:22 AM
