airbag light on intermitently
Old Apr 7, 2004 | 01:33 PM
drcolt
my 92 now has a the airbag light slowly blinking.
Is this common? Ive had it for over 5yrs, and never seen this.
Old Apr 7, 2004 | 06:31 PM
usmanasif's Avatar
similar thing has started happening to me since yesterday. but mine just stays on for 3-5 seconds after starting up (kinda dim), whereas earlier it would go out as soon as i started the car.
Old Apr 7, 2004 | 10:29 PM
drcolt
okay , i fixed the airbag light. Mine was flashing the same, on for 3secs of for 3secs.
After reading thru my Mitchels guide on Demand, the srs system has a self check procedure.
Leave ignition to OFF for 10secs. Open driver door, turn ignition to ON, not start, just ON, toggle the door light switch five times within 7secs of ignition being turned to ON. It will then flash a code for you, if nothing, then the srs system resets, and goes back to normal. Turn ignition back to OFF.
Mine went back to normal, so my light is now off!!
I find it strange as to why it went on, all i was doing was the usual, cranking my tunes, and hit a right hand turn at about 45km/h as hard as i could, trying to loose the back end, but i just cant loose the rear end of my maxima! Shortly after that, the airbag light starts to flash slowly.
My system isnt all THAT loud, its a consistent 143-144db with just a single 15" Vega sub!
Tha Maxipad must be sold. Offers are welcome.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Colossus
Sep 9, 2015 05:46 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
