Testing fuel pump?
Old Apr 10, 2004 | 10:07 AM
mpdugg's Avatar
Testing fuel pump?
Is there a way to test the fuel pump without any special pressure testing tools? Is it not recommended that I pull the fuel linefrom the engine side of the fuel filter and catch the ful in a container (if any comes out)?
Cheers,
Matthew
Old Apr 10, 2004 | 11:04 AM
Mizeree_X's Avatar
Getting back to his roots
Cheers,
Matthew
You can check the resistance of the fuel pump with a multimeter. I forget where the connector is, you'd have to check a service manual. You can also check the fuel pump relay (it's in the trunk right behind the middle panel of the trunklid).
Old Apr 10, 2004 | 12:11 PM
mpdugg's Avatar
Resistance is 1 Ohm
The manual says if the resistance is not .5 ohms then replace the pump. Mine came back with 1.0. The roundness of the number makes me wonder if 1.0 is not the correct number. Could the manual be wrong? I heard the 92 came with 2 different fuel pumps.
Cheers,
Matthew
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
