starting problems
Old Apr 13, 2004 | 01:05 PM
Engloid's Avatar
starting problems
Well, I had a timing belt jump on me recently in my 92gxe. I decided to just go ahead and pull the heads and do everything while in it. Anyway, it's all back together, and I can't get the thing started. The timing belt is correct. I checked it at least twice, using mirror and such. When I crank it, it sounds as it should, with nice compression. The distributor is in correct also. I get fuel out of the filter, and also get fuel comming back out the return...so the rail has fuel.
No matter how much I crank, I can't even smell gas from the tailpipe. I'm thinking my injectors aren't firing any fuel.
I put a meter in one of the injector harnesses, and it is getting pulses of power when I crank the engine. I'm also getting spark to the plugs.
I'm going to be going back down to the garage later on and figured I'd drop a post and get other ideas and input as to what to do/try when I go down there.
I'm thinking I will begin by putting 12v to each injector and verify that they are working. Most likely this isn't a problem since the engine ran great before the timing belt jumped, but I may as well check it.
any other ideas I should pursue?
Old Apr 13, 2004 | 01:34 PM
Jeff92se's Avatar
I'm needing a caw
Hmm I think you are on the right track. Is the injector harness getting power? Have you double checked all your electrical connections? Fuses?? Stray ground wire not hooked up?
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
