Lock Cylinder....bout to replace.....need some advice
I am planning on ordering a new lock cylinder on 4/16/2004. The sympton that I am having now is that I can only lock the driver side door when i'm intending to lock all the doors. I can lock the doors fine from the inside but the driver side door only locks the driver side door. I am now manually locking all the doors except the driver side door from the inside. I then lock the driver side door from the outside and get on my way.....
Anyone had this problem and if so how hard is it to reinstall??
*P.S.* Gas prices just hit $2 for regular.....WTF
I haven't had this problem, but I did just finish putting all 4 door handles together and back onto my car yesterday.
Since you have an SE and therefore no keypads, it should be fairly easy. The wires that go to the front door handles were a huge hassle to deal with. Switching the lock cylinder in a door handle should be a fairly easy process, they come apart and go back together very straight forward.
There are a bunch of pieces that go on the door handle which I have no clue what they did... Are you positive that the cylinder is the problem?
What do you guys think?
Just lock them from the inside
Anyone else?
our cars have the feature where when you lock the doors from the inside and then clsoe the door to go somewhere, they will automatically unlock all the doors.
solution? cheapy ebay keyless entry
Alright. Thanks for the thoughts guys. I'm going to try the door handle thing and sorry Paul bout accusing you of talking crap....it's hard when you can't see how people say things and their facial expressions
I'm probably just going to order the lock cylinder cuz that's what I think the problem is.....
Yeh or Neh on that?
Yeh or Neh on that?
did you try holding the handle up after locking the doors and then closing the door? All early nissans are like that. I usually just push driver's lock down from inside then hold the handle up until the door is closed.
1 do the doos lock and unlock fine with the button on the door?
2 do the doors lock and unlock together if you use the key?( dunno if thas an option, but my cars had it and so do everyone i know)
my doors will lock all together and stay locked if the car is off , key out of the ignition, with either the lock button, the tab that lifts up or the key/touchpad outside. if the car is running and i try to lock the doors they ALL will lock and unlock AGAIN. hope it helps
I'm having that problem from the passenger side. The key will lock the door but only that door, the other's remain up. I had mine at the dealer last month when it was stolen. They told me it was the door lock actuator. Hope that helps some...
2. The key unlocks while the car is running but does not lock.
With the key out the ignition, the car will still not lock every door but the driver side door. I tried that with the tab that lifts up the key (I don't have the keypad on my SE) and it still doesn't work.
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
