VTC question for Mr.Gone..........
Old Apr 15, 2004 | 12:39 AM
5 ltr. beater's Avatar
i already asked this question to red92maxse; and he told me that you might be able to give me a bit more detailed info. on grounding the VTC's. I've heard that you put a toggle switch between your ground and the VTC solenoid ( i was thinking of doing the same thing); anyhow; i was wondering if when you toggle the VTC switch, do you have to shut the car off or can you activate/deactivate the switch while the car is running?
Old Apr 15, 2004 | 07:25 AM
c'mon Mr. Gone...........I know you're out there..............
Old Apr 15, 2004 | 07:30 AM
subs1000w's Avatar
you can do with the car on or off it dont matter
Old Apr 15, 2004 | 07:36 AM
Michael's Avatar
Back in a 3rd Gen.
exactly right. I would sit there with the grounding wire on mine and take it loose and put it back on just to see the idle differences.
Old Apr 15, 2004 | 07:58 AM
thanx guys.
Old Apr 15, 2004 | 11:35 AM
MrGone's Avatar
sorry, lol slept in abit then was out and about.
I tapped the wire right about 6" from the ECU, just because that was the easiest way to do it for the switch.
If you do end up putting them on a switch you will need to tap the wire coming off the ECU going to the solenoid, run a wire from there to the switch, then run a wire from the switch to a ground.
Here is the wire you need to tap:
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
