Turboing a VG
Old Apr 21, 2004 | 12:06 PM
Vector's Avatar
Turboing a VG
I have been looking into it and trying to make up my mind if I want to go through with it. I have been looking at the T3/T4 Hybrids and I like the fact that they spool at low rpms.
I was wondering if anyone knew of a better turbo for the VG and if anyone could help me determine the correct trim, A/R for the compressor and the turbine, the inlet and outlet sizes that run best on this engine. I’ve heard of some people just using 3” inlet and a 2.5” outlet but I thought you had to have some backpressure before the turbo for it to spool up properly.
I'm just about to run out to barns and noble to look for some books on this so that I can figure this out.
Old Apr 21, 2004 | 12:07 PM
Jeff92se's Avatar
I'm needing a caw
Wow. Isn't there a HUGE post about this by mtcookson????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????????????????????
Old Apr 21, 2004 | 12:09 PM
MaximaBalla's Avatar
Yeah, but that's also a VG30ET, this guy is probably talking about trying to turbo his VG in his car.
But, anyways, here is all of the info.
http://www.cardomain.com/member_page...=177457&page=8
Old Apr 21, 2004 | 12:11 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
this is for the entire VGT motor swap, but there is enough info in there to guide you...
http://forums.maxima.org/showthread.php?t=304464
T3/T4 is fine...the best turbos for these cars seem to have .63 exhaust and .60 compressor sides. thats pretty much all you need to worry about...I wouldn't worry too much about the inlet size, most of the T3 and bigger turbos are usually 2.5", its not that big a deal
Jeff92se's Avatar
I'm needing a caw
Which is or isn't covered in the post?
Old Apr 21, 2004 | 12:12 PM
DA-MAX's Avatar
technically the only difference in that writeup should be removing and replacing the motor and a few other small things. but once both motors are in the car its pretty much the same process be it the VG or VGT
Old Apr 21, 2004 | 12:23 PM
Vector's Avatar
Sorry about that guys, didnt know there was already a post, should have looked harder.
Thanks for your help
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
