Man , I m getting frustrating with the engine.
Today , I had a long day and probably did the ten hour worked on my car today and took off the front end. Anyways , I am wondering if any one of you guys know what is the major problem with the idle engine when I put the shift in drive ( automatic ) then the engine goes like low idle n shaking. When put the shift in as P ( park ) it goes smooth. I checked on the ECU and there isnt no ECU codes came on then I tried to adjust the ecu so it came up the same but little better. I was thinking probably the EGR vavle or maybe a new spark plug wire whatever it is called. ? I already had the engine tuned up like spark plug , fuel filter and PVC vavle ( I haven't put PVC vavle in it yet.) Anyone know what is the problem?
Thanks.
Thanks.
What do you mean by "adjust" the ECU?
You mean maybe you have a bad coil pack, since there are no spark plug wires?
Another possibility is the throttle position sensor, but I can't tell without looking at it.
He might mean the "idle adjuster" thing on the computer behind/under the stereo, when I stripped my car I saw it and wanted to play around with it but decided it was for the better if I didn't...
What i mean was is that there is a adjust to turn it up or down with a screwdriver right next to the code number. Thats right there is no spark plug wire but I don't know what it is called , You are right it is coil pack.
Where is throttle position sensor located at?
PS: The person who used to own the car , He is extremely unfit to own the maximas cuz It came out with a grime ( you name it anything ). Some of things that got replaced yesterday and everything came out BLACK like fuel filter , throttle body , air filter, spark plug and oil.
BTW , I wanted to make sure where the ECU code located at , is it on the right side on the ECU where there is adjusting right next to the code number?
The only thing I know when I turn the key igintion on the red light goes on before it starts up and theres no code light on.
litch
123
01-04-2024 07:01 PM
James92SE
142
01-02-2024 09:23 AM
Dasmith
09-23-2015 08:28 PM
