eibach springs
eibach springs
I just ordered a set of Eibach's off of Ebay finally. Do you guys think the stock struts will be ok with these since the drop isn't all that low or will they not handle the drop very well?
nope, they were the ones that were $175 b.i.n. there's one set left for that price. http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
i believe my struts are on their way out since they have more than 150k on them so I'll get them replaced as soon as I can. What's bad about the KYB's?
Funny
Well I had the Tokicos because I could only afford one thing at a time back then on with stock springs. It had a firm ride I could tell the difference when I changed over from my blown stock ones.
But then when I put the Ebiachs/tokicos combo together there was a bigger overall difference. The handling difference is much improved although next time I am going to try to get some better tires although the Kumho 711s they dont grip quite has good in some corners.
I just think that down the road you fellas with the KYBs and lowerings springs are going to be hurting just because of the fact of the spring rating load difference being better oriented with the high performance struts. But if it is good now then that is great and hope it stays that way.
But to each their own and saves the wallet from emptying out too.
Anybody remember KeveinClef? The guy who put together the 3 guage pod piller deal? My friend owns his car now. It had KYB and sprint. The struts are sssooooooooooo trashed. He will be installing tokicos soon. I've got KYB's on my '89. I wish I didn't. I had Tokico on my "old" '93 and I've got Koni on my '92 SE. You get what you pay for, and KYB's are CHEAP.
It isn't that KYBs are cheap, because they are good shocks. The reason they are sooo trashed is because they are designed to be a better than stock replacement, used in conjunction with stock springs for slightly better handling. They just aren't up to the spring rates of the prokits. My friend has AGXs on his 240 and we love them, and i have 14 year old Gas-A-Justs on my car and they're just fine.
Kyle - attending Ore. State, while my lil <a href='http://www.super-crush.com/gallery/klr142'>68 142 (74 b20, broken m40)</a> sleeps... (check out my cardomain site,<a href='http://www.cardomain.com/id/kneedsacar'>kneedsacar</a>
I've had KYB with eibach for probably 3 years now and they still handle very nicely and give a smooth ride too. awsm66 has riden in my car and commented on how smooth it was on the freeway. I know brandon90gxe has the same setup for 2 years or so and is still liking it too.
Tokico HPs are not much different than KYB GR-2s except for the price. They're both non-adjustable gas struts. On both KYBs and Tokicos websites it says that the GR-2 and HP are designed to give equal or better ride comfort than OEM struts. They're both technically OEM replacements but they are stiffer.
I did not know you were on KYBs I thought you were on either Koni or Tokico!!
Well that is good that they are working out for you.
Hmm I found something else a set of four struts that are almost similar as kyb-gr2 and they are on sale for 99 dollars.http://www.suspensionmax.com/
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
