Rev Limiter?
Old May 1, 2004 | 09:54 PM
91WBSE's Avatar
Rev Limiter?
Is there a rev limiter on a 91 SE?
Tonight pulling out of a parking lot with traffic coming I floored it then let up a little. Usually with that much throttle it would shift at 4k or so but it didn't. My music was kinda loud so i couldnt hear engine, then I noticed the shifter(auto) was in 1st. I know it went to redline or a little passed it. If there is a rev limiter, what rpms does it kick in? Anyone?
Old May 1, 2004 | 10:14 PM
jaguax's Avatar
I believe at 7k... if not, somewhere between 6 and 7. Correct me if I'm wrong.
You had the shifter at the "1" position? Why? Are you trying to shift your auto manually? hehe
Old May 1, 2004 | 10:32 PM
91WBSE's Avatar
No haha......but since I have the worn shifter bushing or whatever it is, I shift it from Park straight back to 2nd usually to get it to engage then I tap it up to Drive. This time I guess I wasnt payin attention and went back to 1st and left it there
Old May 2, 2004 | 07:17 AM
Scope's Avatar
Im izz sexay
When I floor my auto I sometimes see the rpms raise to 8k.
Old May 2, 2004 | 07:55 AM
90SEBlack's Avatar
8k thats offly high is the tach functioning properly, U dont wanna go that high anyway theres no power with a ve or vg that high in the RPM range heads just dont breath good enough.If it really is going that high be carefull ur gunna shoot a rod out the side of the block.
Old May 2, 2004 | 03:36 PM
Scope's Avatar
Im izz sexay
It doesnt stay at 8k but it'll jump from 6k to 8k then the engine will settle.
Old May 2, 2004 | 06:44 PM
95turbo gxe's Avatar
im thinking on a gxe vg30e its somewhere around 6300rpms . Because
my when my auto shifts from 1 to 2nd its shift at 6300 and I can hear
the fuel cutout for a milla second and it will grab second and go.
Old May 2, 2004 | 07:06 PM
subs1000w's Avatar
i think on a vg its at 6k on a ve its at 6.6k
Old May 2, 2004 | 07:35 PM
fastflyingasian's Avatar
i have a vg manual and i have no limiter. i can pass 6.5k and even 7.5. unfortunetly i know cause i almost beat the sh-- out of my friend when he was driving and i was in the pass seat.he fried first gear and i noticed the needle coming back down past 7. he hit second and i told him to pull his *** over i'm driving . and i still have never let him drive my car again hehe
Old May 3, 2004 | 05:05 AM
acidspit86's Avatar
i have a vg manual and revs stop at exactly 6000 no matter what
Old May 3, 2004 | 05:47 AM
Kyle's Avatar
I thing that is it 6.7 on a VE manual. If I were yall I wouldn't be trying to hit the rev limiter all the time. Have you ever seen the insides of a scattered engine?
Old May 3, 2004 | 01:35 PM
90maxgxe's Avatar
I have a gxe VG auto and it shifts at 6200 rpms.
Old May 3, 2004 | 10:00 PM
bonzelite's Avatar
that is right. 6k is the limit of the dashed redline. i've seen the tach over that, but i'm stalling out at that point. i'm glad the limiter is there because i have a lead foot and our cars can't benefit anyway from it being removed.
Old May 11, 2004 | 11:59 AM
tranceyboy's Avatar
Ve30 de No rev limiter here, i can make her sing *** high as her physics will allow her. 93 5spd.
Old May 11, 2004 | 04:48 PM
Bill Brasky's Avatar
Seperated at Birth?
uhh... no you cant. well, maybe if you're flying down the freeway and throw it in 1st... but still
vg manual rev-limiter kicks in at 6.3-6.5
Old May 11, 2004 | 07:34 PM
mtcookson's Avatar
vg has a fuel cut rev limiter at 6000 rpm. if you go that high it can rev past it but can be quite dangerous. little/no fuel makes high combustion chamber temps which can cause detonation. my clutch has slipped a few times causing the rpms to raise to 6500 rpm (according to my s-afc) however i saw the needle hit 7000 at one point. scared the **** out of me and ****ed me off as well. the knock reading was around 150 or so which is quite high. normal driving usually doesn't raise the number any higher than 20-30. (normal for me is basically accelerating as fast as i can to the speed limit and then staying at about 5 over the limit)
02PearlSE
Feb 1, 2016 12:37 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
JoshG
51
Sep 21, 2015 10:41 PM
