speedo not working
Old May 7, 2004 | 05:21 PM
white90se's Avatar
speedo not working
so i just bought an 89 5-spd off ebay the other day...i'm driving home and i notice the speedo not working...the tach works fine the but speedo doesn't...so i figured i'd swap my gauges from my wrecked max and everything will be fine...today i do that and the speedo still doesn't work...is there a speed sensor on the tranny that could possibly be bad?? and now my odometer doesn't work either...any help would be appreciated...thanks
will
Old May 8, 2004 | 07:04 AM
djslinkyz's Avatar
it could be the speed sensor. the reason the odometer doesn't work is because it runs off the speedometer. there's a little cable from the odo to the speedo on the back of the cluster
Old May 8, 2004 | 07:00 PM
white90se's Avatar
will an AT speed sensor work on an MT car?? im thinkin the answer is no....but i just want to make sure...thanks
will
Old May 8, 2004 | 08:59 PM
MrGone's Avatar
djslinkyz- I've taken apart a few clusters and there is no cable, there are wires (electrical) but no cable (mechanical).
white90se- IIRC you must use a 5spd speed sensor, I do not remember if the VE 5spd VSS will work with the VG 5spd. (VSS=Vechical Speed Sensor)
Old May 9, 2004 | 06:47 AM
djslinkyz's Avatar
yeah, cable was the wrong word. i meant the little plug with wires.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
