rear tail light fuse blowing
Old May 9, 2004 | 07:42 PM
95turbo gxe's Avatar
For some reason all of a sudden tonight my rear tail light fuse
blows???????? Well It controls your dash lights corner lights etc..
Does anyone know why this is happening ? I can put a knew fuse in
and it takes like a minute and then it blows. I did the corner light rewirer
about two weeks ago. But i did a clean job on it except cover the red wire back
BUT I cut it clean so would not think its that. HELLLLLLLLLLLLLLLLPPP!!!!!!!!
Old May 9, 2004 | 10:46 PM
ChrisCheezer's Avatar
well somthing is shorting out.. i dont know if thoes corner lights are on the same fuse as the dash/tail light fuse, but i would check every part of that re wire.. make sure the wires arent hitting eachother too....
did u install anything interior?? radio... neons..chrome skull shift ***** with red LED's for eyes....
have u check the tail lights? i would check every single wire going to each harness/bulb and ur bound to come across a wire shorting out on somthing. goodluck
Old May 9, 2004 | 11:03 PM
Bill Brasky's Avatar
Seperated at Birth?
redo the corner rewire. that happened to me. too much wattage for that relay/fuse to handle (did the uber-bright corners a-la MrGone)
cover every single junction with liquid elec. tape too. helps a bunch.
Old May 10, 2004 | 04:26 AM
well I havent got anything other than the dimmer wire for the radio
in the itererior that has anything to do with that fuse. I guess the dimmer
wire is with it too, because it dont dim anymore. But ill start checking all those places. If i redo the corner light wiring what should I do to it. saying that its too much watage
Old May 10, 2004 | 08:01 AM
MaximamixaM's Avatar
Very common problem. Either the rear lamp sockets are melting and shorting out, or less likely a bad rear bulb, or a cornering light rewire attempt, or improperly installed radio, or maybe the dimmer switch or light switch on the column. I think all have been listed as a possiblity when I had the problem and searched a year ago. Sometimes it was a radio or cornering light rewire-and didn't show up for a length of time. Then again, it could be the rear lamps/sockets.
Old May 10, 2004 | 12:39 PM
aw89maxSE's Avatar
Yeah man, that sucks to have that fuse blow. I was on my way down to oregon at 10pm when mine blew. No taillights and no dashlights or corners. Had to starting using hazards after people were constantly flasking me HA! I had no idea at all........Luckily, I remembered somone saying something about the fuses on the .org
Old May 10, 2004 | 07:36 PM
well did not have time today to srearch it down but I put a 15 in and
it blew it right away. But i got a 25 in it for now and it has not blown it. I know it dangerous and I will try to search it down tommorow. IF YOU ALL HAVE ANY MORE IDEAS LET ME KNOW THANKS
Old May 10, 2004 | 08:26 PM
I would not recommend the 25amp fuse. You do not want to burn out a wire somewhere, besides the risk of fire, you would then get to find a needle in a haystack somewhere else. I would undo the corner rewire first- I think some people have had trouble with it. When my rear light socket went bad, 10 amp fuses would break quickly.
Old May 10, 2004 | 08:30 PM
Likely it is the corner rewire or the rear lamp sockets. I think all the turn signals work normally with that fuse burned out, and I think the brake lights work with the fuse burned out-verify that. But if that's true, you could drive safely during the day with that fuse out. Of course, at night you wouldn't have rear corner lights.
Old May 11, 2004 | 06:15 PM
Well i got around to checking it out today. all it was a bad tail light
socket. So off to the junk yard I went got it put it back and I put my 10 amp
fuse bad in with no problems. The corner light rewire was fine. Thanks again
everybody!
Old Jun 6, 2004 | 10:25 PM
TEK N9NE's Avatar
Crazy...Im having the same damn problem right now...I have never touched any of the wiring in the car...Problem just occurred outta nowhere...Ill try some of the solutions posted in this thread...peace
Old Jun 7, 2004 | 05:53 AM
Paul89SE's Avatar
It's YOUR STEREO. Check your wiring, chances are it's not grounded properly. I had the same problem and everyone told me it was the tail lamp sockets.
Old Jun 7, 2004 | 03:09 PM
DMad8724's Avatar
I rewired my corner lights and mine never blew, but when I did someone elses, I had the ground wire connecting to something wrong and it kept blowing, check the wiring diagram a couple times.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
220k+ A32
Aug 17, 2015 03:57 PM
doobadoo
Aug 15, 2015 06:43 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
