Widest wheel
Old May 13, 2004 | 04:19 PM
ferran586's Avatar
Widest wheel
What is the widest wheel that will fit on the 3rd gen maximas safely?
Old May 14, 2004 | 06:23 AM
internetautomar's Avatar
mod or sell?
12" with tubs
Old May 14, 2004 | 06:56 AM
Matt93SE's Avatar
STFU n00b!
widest I've actually been able to cram in the rear wheel well is a 17x8. you'll need 32-35mm offset on them. maybe a hair outside that range, but with the 32mm offset I had to roll my rear fenders a bit.
the 35 is very close to the strut housing, so you can't go much past that either.
really limits you on 8" wide wheels that will fit, but most of the better wheels will have them in those sizes. the typical ricer wheels don't get wide enough or have too much offset. (you can run a 17x7 w/ 45mm offset no problem). when you get to stuff like Volk, Work, 5Zigen, MAS, some Konigs and many of the good Enkei wheels you'll find stuff that fits.
expect to pay $200 a wheel absolute minimum for stuff like that.
Old May 14, 2004 | 07:20 AM
Cheocwa's Avatar
Is it pretty much the same for the front? Also what would be a good tire size so it will not rub? like 235 45's?
Old May 14, 2004 | 07:38 AM
Matt93SE's Avatar
STFU n00b!
that's what I've been using for a while, with good results. can't go much wider..
Jeff (and may others) is/are using Mustang wheels with some different offsets.. .but I think they hit the fenders if you bottom out in the back.
the fronts, you can go a bit wider, but I don't know why you'd want to run staggers.. the rears are the narrow point on the 3rd gens. 4 and 5 gens are opposite.
Old May 14, 2004 | 04:23 PM
ferran586's Avatar
Does anyone know the offset of the mustang wheels on a 95 GT? I ask because I know a guy that will sell them to me (tire and all) for $100. And I really dont wanna pass up the deal if the will fit fine. I believe the wheels are 17x8.
Old May 14, 2004 | 04:34 PM
ferran586's Avatar
Nevermind my last question. I just found the info on 4DSC.com.
Old May 15, 2004 | 10:03 PM
xnyc's Avatar
not to steal your thread ferran586 but since were on the subject, will 235/45/17 fit on a 17x7 rim or will the tire be too wide?
Old May 16, 2004 | 01:21 AM
Cheocwa's Avatar
it depends on the tire, but mostlikely.
Old May 16, 2004 | 08:40 AM
xnyc's Avatar
mostlikely it will be too wide or mostlikely it will fit? im going to be using kumho 711s. cheapest bang for the buck like everyone on tirerack said.
Old May 16, 2004 | 08:44 AM
Matt93SE's Avatar
STFU n00b!
should be okay, but call your tire dealer and ask them.
Old May 16, 2004 | 11:53 AM
bonzelite's Avatar
it will fit. but i would only feel safe when cornering under "spirited driving" with 225's at that rim width. a 235 with the 45 sidewall is borderline too thin to solidly mount into the depths of the 7" wide rim lips.
also, 225's just, just fit flush and nice, whilst a 235 may have you sticking out of the guards.
i've never run 235's, mind you, but i can see the potential flaws in choosing those. and based on what tires and rims i have run, i would not choose 235's at all.
Old May 17, 2004 | 06:16 PM
xnyc's Avatar
thx for the help
Old May 17, 2004 | 06:40 PM
mtcookson's Avatar
would 245/40-17 fit with the 17x8 mustang gt wheels?
Old May 17, 2004 | 07:04 PM
HTPerformance's Avatar
They will, but might rub, try to find 235/ 45,
maybe even 245/ 50 would be better??
Brian
Old May 17, 2004 | 07:31 PM
mtcookson's Avatar
hmm... maybe i could put some spacers on and longer studs if needed. i'd like to get the widest tire i can on there.
Old May 17, 2004 | 07:54 PM
Matt93SE's Avatar
STFU n00b!
other way.. they'll rub on the fenders, not the struts.
Old May 17, 2004 | 08:56 PM
mtcookson's Avatar
oh... well then i guess spacers wouldn't help me
Old May 17, 2004 | 10:06 PM
bonzelite's Avatar
i'd steer away from spacer-land if you can help it.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
