Antenna stuck
May 17, 2004 | 09:13 AM
The power antenna on my '91 GXE is stuck in the up position. When I turn the stereo off I hear the motor running trying to pull it down but it doesn't go anywhere. I can't even push it down. This happen to anyone else? Is it fixable or should I give up and buy a new antenna?
May 17, 2004 | 10:43 AM
sounds like your mast isnt catching by the way of the motor, but not being able to push it down, maybe its bent, a new mast might fix it. mine wouldnt go down either, but i had to push REALLY hard then it went down.
May 17, 2004 | 12:26 PM
I have the same problem. If you get an answer let me know. Someone said that we have to replace the entire moor
May 17, 2004 | 12:27 PM
I have the same problem. If you get an answer let me know. Someone said that we have to replace the entire motor
