Error codes and TSB information!
Old May 17, 2004 | 10:47 AM
Jeff92se's Avatar
I'm needing a caw
Error codes. Thanks to indy650n00b
http://pages.cthome.net/bbachinsky/nissan_ecm_codes.htm
So you guys can stop posting error code threads now
Old May 17, 2004 | 12:03 PM
reygarcia's Avatar
Loved by MrGone longtime
Now you have to get them to read the stickies.
Old May 17, 2004 | 12:48 PM
mtcookson's Avatar
for our cars:
code 13 is coolant temperature
code 33 is o2 sensor
Old Jun 5, 2004 | 06:16 PM
goon9's Avatar
Bare with me, I'm new to diagnostics. How do u get these codes???
Old Jun 6, 2004 | 06:23 AM
reygarcia's Avatar
it tells you in the haynes manual, if you have one.
but basically when you are looking at your ecu, there is a slotted **** that you turn and it starts the diagnostic test that you select. then read the number of flashes per LED on it and you get your code.
Old Jun 6, 2004 | 07:20 AM
mtcookson's Avatar
turn the screw clockwise and wait for the leds to flash 3 times then turn it back counter clockwise. this is the diagnostics mode. from here the leds will flash individually indicating the code. the red led indicates the 10's and the green led indicates the 1's. i.e. if the red led flashes 2 times and the green led flashes 3 that would be code 23.
Old Jun 6, 2004 | 01:13 PM
mtcookson's Avatar
page 153 i think has all of the codes and such. somewhere in the 150's at least.
Old Jun 30, 2004 | 08:28 AM
Jeff92se's Avatar
I'm needing a caw
TSB information thanks to D-sta!
http://maxima.theowensfamily.com/tsb/
Old Aug 22, 2004 | 07:17 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
so if i set it to diag mode and turn the car on and it dosent flash at all i can assume that everything is good ?
Old Oct 20, 2004 | 01:17 AM
89maxSE's Avatar
Sounds like you do it a little different than I do. Turn the key to the "ON" position. Then turn the little screw on the ECU clockwise, wait for 2 seconds, then turn it back counter clockwise . Then the red light will flash in 2 sequences. Slow flashes indicate the first digit of the number, Fast flashes will indicate the 2nd digit of the number. Say it goes "flash....flash....flash...........flash.flash.fla sh....." That would be a code 33 which is o2 senor. If there are no codes in the ECU it would read 55. Turn the screw counter clockwise, hold it then turn it back to the original position.
Old Dec 10, 2004 | 12:52 PM
Phatsta's Avatar
My -91 is just like this, think they're different on older/newer models...
Old Dec 10, 2004 | 04:22 PM
89maxSE's Avatar
well it worked the same way on both my 89 and 94
Old Mar 17, 2009 | 11:29 AM
smokphattys's Avatar
ok, so i turned the screw clockwise and the light goes out, if i turn it back the light comes back on and does nothing, if i leave it turned the light flashes 2-slow, 3 fast, 4 fast, 5 fast, 1 slow. help me out
Old Mar 17, 2009 | 02:18 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
do you have a VG or VE? either way, the info is in the general maintainence sticky. click here http://forums.maxima.org/3rd-generat...-then-off.html then read post 5 if you have a VE, and posts 5 and 12 if you have a VG
maxinout93
Oct 31, 2015 02:04 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
