Manifold Patch?
Old May 17, 2004 | 11:05 AM
cardshark's Avatar
Manifold Patch?
I have a cracked exhaust manifold (91 SE Auto) and my mechanic said it didn't affect anything if I didn't fix it, that it'd just be an annoying noise to deal with. Are there patches for this or can it be welded over instead of replaced? If not, what does this job run? I just graduated college and this expense was not part of the plans...
Thanks for any help.
Old May 17, 2004 | 11:12 AM
indy650n00b's Avatar
Depending on where and how big the crack is it can be welded. Your best bet would be to take it out (your going to have to anyways) and take it to an exhaust shop and they should be able to weld it up cheap.
Old May 17, 2004 | 11:40 AM
Matt93SE's Avatar
STFU n00b!
Yeah, what he said..
often times, it's the manifold studs are broken on the engine, causing the manifold itself to crack... make sure you have that part fixed, then you should be able to weld up the manifold and be good to go.
Old May 17, 2004 | 11:44 AM
cardshark's Avatar
That's what I wanted to hear. I already did the studs last year, it was cracked from a bad tow job. Thanks again.
Old May 21, 2004 | 07:44 AM
Dougn's Avatar
My rear (back) exhaust manifold also leak and have a bolt broke off. How hard is this to remove the manifold? My local mechanic gave me an estimate of $1,200 to replaced and fix the broken bolt.
Thanks is advance for your help.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Oct 24, 2015 08:05 AM
JonBlz
Oct 5, 2015 06:02 PM
dshinn
Sep 26, 2015 08:07 PM
