I need to get through the firewall
Old Mar 26, 2001 | 01:56 PM
primeevil711's Avatar
Wussup guys I'm having some trouble wiring some of my goodies because getting past the firewall in my car is hard as hell. can anyone tell me a good place to get through and how they did it. thanx in advance.
Old Mar 26, 2001 | 02:22 PM
93 SE's Avatar
i just went through that process couple days ago ...i didnt have a drill so i had to find another way...i read to go through wheelwell and hood cable....take off the cover under wheelwell and find hood cable and put your wire through there ,you have to remove the gromet for hood cable as well for wire to fit
Old Mar 26, 2001 | 02:31 PM
Matt93SE's Avatar
STFU n00b!
Yup.. as he said..
to make it a little more clear, remove the LEFT side fender well. jacking up the car or removing the wheel makes this much easier, but it's still not difficult.
once you get there, you'll see exactly what needs to be done.
Old Mar 26, 2001 | 04:32 PM
bigjay's Avatar
or you could do it the right way and go threw the factory rubber seal with a drill and run it threw there, its on the drivers side, just pull back the carpet a little bit to get your drill in beter, it took me all of 1 1/2 minutes
Old Mar 26, 2001 | 09:41 PM
The Sleeper's Avatar
grommet
any idea where this stock grommet is on the drivers side? i looked and cannot find it.
Old Mar 26, 2001 | 09:58 PM
Matt93SE's Avatar
STFU n00b!
It's way up under the dash if you're looking at it from inside the car..
if you're looking at it from inside the wheel well, it's pretty obvious.
here's a pic..
Old Mar 26, 2001 | 10:02 PM
thanks matt- i'll have to look into that as opposed to having a stereo shop charge me $40 each for two amps to be installed. any idea if that will accomodate a 4-awg wire?
my clarion cd deck is having problems, i hate best buy...
while i'm here - anyone have a spare set of mirrors to sell?
Old Mar 26, 2001 | 10:06 PM
Matt93SE's Avatar
STFU n00b!
See that "clean" black wire running through there?
that's a piece of 2awg wire with 2 split-loom tubing over it. if that can fit in there, you'll have no problems with some 4 awg.
Old Mar 26, 2001 | 10:13 PM
<phew> and i thought i was gonna have to drill. makes me smile even though my max is ugly looking from the punks who broke my mirrors off... after the stereo its alarm time. looking for one with a pager. recommendations anyone?
Old Mar 27, 2001 | 12:23 PM
nubiannupe's Avatar
OG Maxima.org Member
I think someone was selling a Crimestopper in the 'for sale' forum. I'm not sure, though.
Old Mar 27, 2001 | 06:42 PM
Evil Yak's Avatar
I know drilling is bad, but I drilled a hole right next to the throttle cable and the brake master cylinder on the
firewall. I guess I just have a little too much fun with the stuff...
Old Mar 29, 2001 | 02:05 PM
Jesse93GXE's Avatar
I also drilled near the brake cylinder. 8" to the drivers side of it, same height as its center. Nice and clear on both sides. Popped in a grommet and ran the cable through.
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
