ignition coil
Old May 24, 2004 | 03:20 PM
Irish's Avatar
This is a democracy
ignition coil
is it hard to replace the ignition coil in my VE? i just got all new fuel injectors, but my car still has hesitation, im replaceing the sparkplugs and thought replaceing ignition coils too. is there any visual ways to tell that an ignition coil is burnt out? thanks
~Irish~
Old May 24, 2004 | 03:41 PM
jwmaxse's Avatar
VE's have a direct ignition system w/ a coil/spark plug combo over each spark plug, they're called coil packs. They are easy to pull, just unbolt them, pull the plug, and pull the entire piece off of the spark plug. You can check them visually by looking for cracks on the boot once they are pulled, or you can check them with a multimeter, do you have a multimeter?
Old May 24, 2004 | 04:36 PM
Irish's Avatar
This is a democracy
i dont think so, so when you pull out the plug, do you replace the whole long plug or is there something inside of that that needs to be replaced?
Old May 24, 2004 | 04:48 PM
GReDdyXMaXiMa
I have a set of assembly coil packs which I got new one today. one is little bit cracked and thats about it. I m going to sell it all for set for cheap price.
Old May 24, 2004 | 05:20 PM
jwmaxse's Avatar
If the insulation or boot on your coil packs is all cracked, I think you just have to buy the whole piece, which is like $60 per coil pack. Some .org members have actually wrapped electrical tape around the boot and I think they have had positive results.
Before you go and replace all these parts though, are you sure that the coil packs are the problem? What symptoms is does your car have? A common VE problem is the Knock Sensor (KS) and the KS harness corroding and that will cause hesitation. I would recommend pulling the codes at autozone or something, or possibly putting a resistor in to bypass the KS to see if that fixes your problem.
Old May 24, 2004 | 06:52 PM
Cliff Clavin's Avatar
Way out West
here are the front three...one 10mm socket and the electric plug, then pull the coil pack off. The back three have two 10mm sockets on each one.
my problem was the rear coil packs. I am not sure which one (s) but I got three from a parts car and it's all good now.
Initially, my car would idle wierd and that was because I had a cracked front coil pack. When I replaced that, the idle got better, but it still stalled/hesitated. When I replaced all three rears, I haven't had it stall since.
Old May 25, 2004 | 12:03 PM
Irish's Avatar
This is a democracy
rosa, your from elgin? my ma is from there, got some family in streamwood, but thats beside the point, i just got my injectors replaced and i still have a hesitation through out probably 1700-2500 rpm, feels like something is pulling the back of my car and keeping me from going, and then after 2500rpm it accelerates really fast and shifts hard and then runs fine, it still isnt running like it was before i got the injectors fixed.before the injectors started going out my car was running fast as L (hel!) but after a while it started to run like crap again, thats why i think it is the ignition coils/spark plugs, before i could tell that the injectors were plugged up cause you could hear them stuttering, now theres fuel there( a full clean stream from what i can hear) but its still hesitating. any ideas?
Old May 26, 2004 | 10:56 AM
Irish's Avatar
This is a democracy
where is the KS located and how do i get a resistor to bypass, i know my KS is bad cause my ive got a horrible knocking in the engine. help???
Old May 26, 2004 | 11:41 AM
jwmaxse's Avatar
Yes, I live near Elgin, but I'm from Iowa originally. Anyway, If your motor is actually knocking I don't know what to tell you other than use premium fuel and check your timing. Here is some good info on the KS:
http://www.4dsc.com/articles/drivetr...k_sensor.shtml
If your motor is actually knocking, don't put a resistor in there or you could seriously damage it.
Old May 26, 2004 | 02:43 PM
Irish's Avatar
This is a democracy
so what do you think the loud knock coming from my engine is? is this problem bad,or is it something that can be fixed pretty easily, pleaseeee say easily...
Old May 27, 2004 | 07:40 PM
internetautomar's Avatar
mod or sell?
VTCs........
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
