Something slippin...Bogs?
Old May 27, 2004 | 02:59 PM
Maxima90SE's Avatar
first off...i have a VG 5 speed,
the clutch has been replaced last summer
well i was drivin in 2nd gear and around 3k rpm...it felt as if somethin was slippin. it kinda felt like a clutch slippin but it wasnt that casue the RPMs didnt go up but stayed at 3k rpm until it fianlly got some power back. My spark plugs, wires and dist cap have been replaced bout 2 yrs ago
what would make this happen?
i am replacin my belts and timin belt this weekend...could it be the belts?
Old May 28, 2004 | 02:58 PM
Maxima90SE's Avatar
bump.......anyone know what is up with that?
Old May 28, 2004 | 09:05 PM
XmaximaX's Avatar
Is there a specific time when it happens, like when it's wet out? If it is then spray down your ignition system with water in a spray bottle and try to find arcs, then replace that part, you might want to try the ignition coil as well.
Old May 29, 2004 | 06:39 PM
Maxima90SE's Avatar
both times it happened it wasnt wet....it was in the middle of the day when the temp was around high 70s and low 80s LOL hmm how can i check the coil? is it possible with the volt meter and if so, what is the range that it is suppose to be at. THanks
Old May 30, 2004 | 02:35 PM
XmaximaX's Avatar
I don't know about with a voltmeter and all, all i had to do was spray it with some water in a spray bottle and i saw an arc from it, and that's how i knew it was bad.
