How do you pull the engine codes ?
Old May 31, 2004 | 09:20 AM
99 Supercab's Avatar
Since the search function is down, I figured I`d bite the bullet and ask. I have a 92 SE.
TIA
The car runs great from a dead stop, but has a bad hesition when trying to accelerate from about 15-20 MPH. I`ve already disabled the VTC, replaced spark plugs, air filter, fuel filter, and have ran 2 bottles of Lucas fuel treatment thru it. Anybody got any ideas ?
Old May 31, 2004 | 09:26 AM
Josh's Avatar
http://autorepair.about.com/library/...bl-dtcs-69.htm
this should tell you how, the rest of the codes are on a sticky.
hope this helps.
Old May 31, 2004 | 05:57 PM
Iron_Curtain's Avatar
99 Supercab, I have the SAME exact problem and I have done almost all the same things you have to fix it. If you find out what the problem is, let me know and Ill do the same.
Old Jun 1, 2004 | 05:42 AM
I`ve been doing some research on it and from what I understand, its either an injector or a fuel pump. I just bought the car to drive back and forth to work, but the more I drive the car, the more I like it, so I`d like to get it running right.
Old Jun 1, 2004 | 03:26 PM
Alright, Thanks. Ill have to check out my fuel pump with my dad, and if that is fine, Ill have a mechanic friend check my injectors. Thanks again. Ill keep ya informed.
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
