Need Motor or Heads
Need Motor or Heads
I need to find a place that sells performance heads for my motor. Any of you guys have any ideas of anywhere except Paeco? Also, if I can make this a 2 part question, where is the best place to buy a complete performance engine? (this is all for a 91 Max SE with a stage 2 subframe and a welded strut tower brace, 18" 6lb. racing rims, CAI, and of coarse a custom interior.)
i don't know many places that sell worked over VG30E's (i was looking yesterday). All i find is VG30DE's and DETT's.... you can buy pistons and cams. you could get your crank re-ground and have some new Eagle h-beams. Someone makes a nice set of valves... JWT for the cams and valvesprings.... it's not that hard to have someone make a custom header...
if you've got the money, the possibilitys are endless.
www.hekimianracing.com has a n/a 300 hp vg30e but is very very expensive. 8000 or more
Actually Engloid does heads. Search the Z31.com and similar sites for performance engine parts for your VG30 sohc. The older Zs have a similar sohc engines and alot of their engine parts should cross over to yours as it's essentially the same inside (except for the Z31 turbo engines but you can even use their parts for boost)
AaronL
Aug 8, 2020 10:31 AM
knight_yyz
Nov 1, 2015 01:34 PM
