AC not working
Old Jun 3, 2004 | 11:39 AM
evilvamp7's Avatar
AC not working
my AC is not cooling i have put R12 in there too and still it's not ccoling can anybody know why
Old Jun 3, 2004 | 11:55 AM
internetautomar's Avatar
mod or sell?
because you haven't diagnosed it.
does the compressor turn on?
have you checked for leaks?
Old Jun 3, 2004 | 11:59 AM
evilvamp7's Avatar
yes the compressor works and i check for the leaks too no leaks and when u turn on the AC the out side AC line is cold but inside it's not
Old Jun 3, 2004 | 12:17 PM
mod or sell?
expansiopn valve could be plugged.
Old Jun 3, 2004 | 12:23 PM
evilvamp7's Avatar
where is that and can u tell me how to change that thanx
Old Jun 3, 2004 | 12:37 PM
mod or sell?
unless you have a MACS certification I can't.
Cause it would cause you to vent the 12 into the air which is illegal.
of course the FSM has that info.
Now if you had an R134a retrofit done instead of the 12......
Old Jun 3, 2004 | 12:55 PM
evilvamp7's Avatar
can i change the R12 R134a and to do that what i have to change and there is that valve
Old Jun 3, 2004 | 01:11 PM
mod or sell?
you'll need to have a shop evacuate the R12 out of the system.
you'll need retrofit fittings, I have to look where the valve is, haven't had to work on mine. ICE cold AC still good from factory (i'm assuming)
Old Jun 3, 2004 | 01:46 PM
evilvamp7's Avatar
when u remove the R12 from the sys then u can put the R134a in there that's it or you have to change some thing in there too
Old Jun 3, 2004 | 05:18 PM
BML94GXE's Avatar
Maxima Withdrawl is real
i belive you have to change some stuff, not positive, but pretty sure
Old Jun 3, 2004 | 05:53 PM
mod or sell?
if you open the system, you should replace the reciever/dryer
BTW that pic was of the expansion valve.
when you recharge the system with r134 don't forget the dye and the oil.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
