egr valve cleaning
Old Jun 10, 2004 | 08:40 PM
bvtran's Avatar
94c Big Max
egr valve cleaning
I heard that it's pretty easy to clean up the carbon deposit inside egr valve. Had anyone here done it with a carb/throttle body cleaner? I just wanted to know if it's doable or not. There were 2 types of EGR valves for passenger cars, pintle vs. recess operation. Pintle is easy to clean, while recess can't be cleaned. Which one is for our car (SOHC)? Please tell me it's doable cuz I dont' feel like forking out $100 for a newer valve.
Old Jun 11, 2004 | 04:45 AM
Mizeree_X's Avatar
Getting back to his roots
Craig's site has a how-to on cleaning the EGR valve for the VE engine, I imagine it would be similar for the VG. I cleaned my EGR valve with some throttle body cleaner and it seemed to work.
Old Jun 11, 2004 | 08:31 AM
bvtran's Avatar
94c Big Max
graig's da man. thanks.
Old Jun 11, 2004 | 08:46 AM
eric93SE's Avatar
I used to use carb cleaner, but I recently took a better look at the design and it looks like it may never need cleaning!
I think its the pintle design that you mentioned. It looks like a piston that plugs a cylinder (sort of like an engine piston and cylinder). So there is no 'seat' to clean, and the motion of the piston in the cylinder should be self cleaning (sort of anyway). So long as its able to move freely, it should be fine. Definitly a smart design by nissan.
Old Jun 11, 2004 | 09:22 AM
«§»Craig B«§»'s Avatar
I noticed a huge difference in emissions after I cleaned mine last year (after failing emissions). The NOx levels were cut WAY down so I think it does help to clean it.
Old Jun 11, 2004 | 05:55 PM
bvtran's Avatar
94c Big Max
Thanks, guys. I greatly appreciate all of your comments. I'll definately tear it looses when my egr gasket gets here.
Old Jun 11, 2004 | 07:36 PM
thumpyls's Avatar
any pics...do u just remove the egr and claen it,then let it dry
shilov
Feb 19, 2024 09:40 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
