Help! What You Means By Grounding The Vtc? N/m
Old Mar 29, 2001 | 07:35 AM
avargas
THANKS
Old Mar 29, 2001 | 07:44 AM
«§»Craig B«§»'s Avatar
grounding the vtc will stop your VTCs from ticking if they've gone bad
how-to in on my page
http://www.prism.gatech.edu/~gte671n/mymax.html
the pic probably wont work so you have to right click on the red X and go to properties, then copy and paste the image location; after that is done for each pic, then the page should work fine
gotta love geocities =)
Old Mar 29, 2001 | 07:59 AM
avargas
TO CRAIG
Hi, do you think can be that the reason, because i feel a loss of power and the ticking noise.
Old Mar 29, 2001 | 08:28 AM
Re: TO CRAIG
it could be; the VTCs are a very common problem for 92-94SE
they usually cause a ticking noise and a slight loss of power like you mentioned so my guess would be that, but I can't tell you for sure
Old Mar 29, 2001 | 09:03 AM
avargas
DO TYOU THINK THAT JUST TO REWIRED WILL FIX THE PROBLEM?
(GROUNDING)
THANKS
Old Mar 29, 2001 | 09:23 AM
(GROUNDING)
THANKS
the rewire stopped the noise on my car and several other peoples
some people say they lose power after it, other say they gain some; I didn't really notice any difference in performance, just the noise is gone which is what I wanted
obviously ground one wire wont mechanically fix the vtcs ,but it just disables them
try it; it only takes 1/2 hour at the very most and it is easily reversible if you dont like it for some reason
Old Mar 29, 2001 | 12:13 PM
dmontzsta's Avatar
Ford Only.
Craig your site isnt working for me.Any ideas how i can get in.I really would like to see how to ground the VTCs
Old Mar 29, 2001 | 12:51 PM
did you try the method above? if so, also try hitting refresh a few times and it should work
geocities is very weird and sometimes works, sometimes doesn't, but I haven't had time to move it to another server
if that doesn't work, email me and I can send you a zip file with the pics and the instructions
craigbrace@hotmail.com
Miket2006
Mar 1, 2021 03:55 AM
wiseguy6199
18
Oct 1, 2015 12:28 AM
zmcneely13
Sep 26, 2015 02:26 PM
mclasser
Sep 24, 2015 11:57 PM
