Quick cigarrette lighter wiring question
Old Jun 12, 2004 | 07:55 PM
elektronic's Avatar
This should be an easy question to answer:
I took apart the dash to hard-wire my sirius PNP tuner. I assume the orange with blue stripe is hot and the black ground coming off the lighter?
I have a voltmeter on order, but this would leave one less thing to screw up if someone has access to a wiring diagram.
TIA,
Jeff
Old Jun 12, 2004 | 07:58 PM
thumpyls's Avatar
if this is ur 1st time w/ wiring wait for the meter/ buy a chiltons..ps try a test light 1st..by grounding the test light u should be able to see if the blue wires the hot one
Old Jun 12, 2004 | 09:13 PM
elektronic's Avatar
I'm an idiot...I should have thought about using a test light to test if it's hot. I'll have my dad with me, he graduated from stevens with an EE degree in 1974. Maybe he can finally put it to use.
I guess I should have payed more attention in Emag, but I have circuits next semester to redeem myself.
Thanks for the quick reply.
Old Jun 13, 2004 | 04:54 AM
internetautomar's Avatar
mod or sell?
also check craig b's site for a wiring color code list.
Old Jun 13, 2004 | 08:46 AM
«§»Craig B«§»'s Avatar
yes, the orange is +12 switched power (turns off when car is off) and black is ground
generally for car (nissan at least) wiring, 99% of the time you find a black wire, it'll be ground
Old Jun 13, 2004 | 07:26 PM
elektronic's Avatar
Generally, I've found black is ground in any application, and red is hot. Going by this, I assumed the orange was ground. Thanks for confirming this. Can't wait for my damn voltmeter to get here and to finish the faceplate for this install. My lighter power splitter and all the wires running to it (from the sirius tuner and radar detector) is fugly.
-Jeff
PS. Thanks for your site, it helped me change my broken window regulator a year or so ago. Saved me $100 vs. going to the auto body shop.
Old Jun 13, 2004 | 08:20 PM
-Jeff
I assume you meant to say orange is power.
Black is ground for most auto applications, but it's usually line voltage in AC systems (ie household wiring) so be careful if you ever mess with that
Old Jun 13, 2004 | 10:11 PM
elektronic's Avatar
Thanks for the tip, my other experience with wiring is in modding computer fans, which would explain the simmilarities...good thing I haven't done any wiring in my apartment yet. Oh, and a belated congrats on getting out.
-Jeff
Old Jun 14, 2004 | 05:09 AM
-Jeff
Thanks Jeff.
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
soloist3
29
Sep 1, 2015 03:47 PM
doobadoo
Aug 15, 2015 06:43 PM
