Temp gauge
Old Jun 16, 2004 | 06:41 AM
MAXI's Avatar
Temp gauge
first off, if it wasn't for this forum, i wouldn't be able to replace my gauge and fix the clock, this site rocks!
now the problem, the temp gauge keeps dropping below the "C" marking, this has been happening even with the original gauges in place.
while driving, it will work normally for about 20 mins then just drops. sometimes it will function normally again, or it will remain dead during the rest of the drive.
what else can I check to fix this problem????
thx
Old Jun 16, 2004 | 07:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
check the sensor? it's on the water inlet by the upper radiator hose. one wire...black boot on it. wiggle it and see if the gauge comes back on.
Old Jun 16, 2004 | 07:53 PM
james93gxe's Avatar
I had that problem and it turned out that the connector was so corroded that it fell off when i wiggled it.
Old Jun 17, 2004 | 07:42 PM
maxima 94's Avatar
you might want to check your thermastat. that might be causing the problem
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
